E30 Garage Clean Out, Tons of Parts!
  • gibbmason@gmail.com
    • Dec 2018
    • 52
    I have a garage full of E30 parts. All are in good used condition. I will provide as much information and pictures as I can for each part. I'm willing to ship anywhere as long as you cover the shipping cost.
    Here's the link to the pictures: https://drive.google.com/open?id=1ex...41MKMFY2NzLcKl
    Here's the list of parts and prices. All prices are or best offer, I'm happy to negotiate to help out fellow rev members. Unless otherwise stated, all parts are OEM, no off brands. Send me a PM if you would like more info on anything.
    -Driver side exterior mirror with wiring from '85 sedan. $60.
    -Interior door b-pillar trim covers set from '85 sedan. $25
    -Pre-facelift tail light bulb trays (left and right) with bulbs. $45
    -Front ashtray in great shape, super clean $50
    -Front ashtray with wood trim. $30
    -Rear ashtray with crack (see pictures) $25
    -Battery negative wire $10
    -Cool owners manual from 85 318i with original sales business card. Kinda cool collector item. $30
    -Lower dashboard trim, piece that sits above steering column and under gauge cluster. $15
    - Handbrake boot and handle, in good shape, no rips. $35
    -Sunvisors with hardware. $35
    -Halogen headlights, no cracks or damage anywhere. $125
    -Upper steering column trim $25
    -XO Vision XD107 Stereo headunit (not OEM part) with wiring. I also have an aux cord for it not pictured. $25
    -Brake booster, master cylinder, and fluid reservoir from a E30 IX model. Perfect for engine swaps as they give you more room in the engine bay. $250
    -Steering wheel badge $5
    -M10 valve cover and oil filler cap in great shape, no damage and I just cleaned it. $70
    -I have two sets of interior air tubing for the A/C and heat. $100 each set.
    -Set of front and rear tan carpet from a sedan. Correct me if I'm wrong, but I think it will fit in a coupe as well. In great shape, just needs a good shampooing. $100
    -Various switches, $10 each
    -Shift boot frame. $5
    -M10 intake air box with filter and bushings. $50
    -Interior B-pillar covers from sedan with mounting screws. $115
    -M10 cooling fan shroud $20
    -Windshield cowl grilles $20
    -Set of 4 exterior door handles $35
    -Brake booster, master cylinder, and fluid reservoir from 85 318i. $100
    -M10 ignition coil, bracket, and spark plug wires $50
    -Idle control unit $35
    -Hood release lever $30
    -Front bumper shocks $70
    -Front seat back panels in tan leather. In great shape $65 for the set
    -Front passenger window with seal, factory blue tint $80
    -Rear driver window with seal, factory blue tint $80
    -Passenger rear triangle glass piece with seal, factory blue tint $60
    -Driver rear triangle glass piece with seal, factory blue tint $60
    -Driver rear window motor and lifter $100
    -M10 water divider $25 SOLD
    -Driver front window motor and lifter $100 SOLD
    -Passenger front window motor and lifter $100 SOLD
    -Trunk torsion bars $35
    -Brake and clutch pedal for manual transmission with pedal support bracket, clutch master cylinder, mounting hardware and springs. $150
    -Interior door handles (passenger and driver, one of each) $15 each
    -Engine bay relay box with 3 relays, cap, and wiring $50
    -Set of tan door cards for sedan $50 each or $150 for the set
    -HVAC box from 1985 318i $75
    -M10 Ignition Control Module $40
    -Accelerator pedal and bracket $40
    -Side seat covers (all four are different, let me know which one you need) $15 each
    -Glovebox side trim $15 SOLD
    -Glovebox hinge $10 SOLD
    -Glovebox light with bulb $10 SOLD
    -Spare wheel holder and wingnut for trunk $10
    -Front ashtray and cigarette lighter holder $40
    -Trunk light with switch and wiring $20
    -Trunk lock complete set. $50
    -Windshield wiper motor, linkage, arms, blades, and hardware $100
    -Handbrake handle with hardware $50
    -Interior air vents (center, left and right) $75
    -Trunk carpeting $75
    -M10 intake manifold, throttle body, and intake boot $150
    -Passenger rear facelift tail light with red tint. $50
    -Rear axles, brand new never used. These are not OEM axles, from a brand called SurTrack. $50 for the set SOLD
    -HVAC box from a 1989 convertible. This one is in great shape and was working great before it was pulled from the car. $150
    -Trunk, engine bay, driver rear, passenger rear, front passenger weather seals. $20 each
    -Rear center seatbelts. $45
    -Left and right front grilles $20 each
    Unless otherwise stated, parts were pulled from a non-running car and function cannot be guaranteed. However, all parts are in great used shape and I did my best to take the best pictures I could.
    Last edited by gibbmason@gmail.com; 07-05-2019, 03:52 PM. Reason: Updating sold parts
    • Dec 2018
    • 52
    bump
    • Mouse
      • 376
      PM'd
      1982 528e - Sold
      1987 325e - Totalled
      1990 325is - Sold
      1997 540i6 - Sold
      1991 325ic - Sold
      2013 335i - Sold
      2005 X5 - Daily
      1991 318is - *work in progress*
      • Mouse
        • 376
        PM'd again, I'll take the trunk bottom.
        1982 528e - Sold
        1990 325is - Sold
        1997 540i6 - Sold
        1991 325ic - Sold
        2013 335i - Sold
        2005 X5 - Daily
        • Mouse
          • 376
          Monies sent for trunk carpet.
          1982 528e - Sold
          1990 325is - Sold
          1997 540i6 - Sold
          1991 325ic - Sold
          2013 335i - Sold
          2005 X5 - Daily
            • Dec 2018
            • 52
            Bump
              • Dec 2018
              • 52
              bump, still have a lot available
              • Project535
                • May 2011
                • 72
                How many sunvisor sets do you have?
                1992 325I Convertible
                  • Dec 2018
                  • 52
                  I have two sets available
                  • Mouse
                    • 376
                    Received my parts. Thanks again. :up:
                    1982 528e - Sold
                    1990 325is - Sold
                    1997 540i6 - Sold
                    1991 325ic - Sold
                    2013 335i - Sold
                    2005 X5 - Daily
                      • Dec 2018
                      • 52
                      No problem, pleasure doing business with you!
                        • Dec 2018
                        • 52
                        bump
                          • Dec 2018
                          • 52
                          Bump
                            • Dec 2018
                            • 52
                            bump
                            • gotblah
                              • Dec 2009
                              • 17
                              Still have the "oh shit" handles I see in the pics?
