OBC Gauge pod replacement panel. Laser cut. LIMITED Qty.
  • Screaming_bmwe30
    • 128
    These are laser cut acrylic gauge panels precisely cut to the opening of the OBC location on E30's. The panel was able to be so accurately cut that it nearly snap fits into the location with only a little bit of superglue or other adhesive necessary to hold it in place.
    Gauge panel is offered in 3 sizes, and there are limited quantities of each size, so hurry while they last.
    2" / 50mm- for some autometer gauges like the ultralight series etc.
    2-1/16" / 55mm- Most sunpro and many autometer gauges are this size (most common gauge size)
    2-5/8" / 66mm- Standard size for plus size gauges offered by autometer and others.
    If you have a caliper, measuer the diameter of the gauge closest to the bezel.
    If you don't have a caliper, wrap a strand of string around gauge, and take that measurement, and do the following math:
    (Measurement of string) divided by 3.14= Gauge Diameter
    12$ shipped (priority mail) per gauge panel and 8$ for each extra.
    add 2$ per panel for textured black coating that matches the interiors black plastic almost perfectly.
    PM me if interested, and I will give you payment information on request. Specify # of panels wanted, and if you want the textured coating.
    -Gauge panels come with a paper backing to protect the side you'd face out (If you choose to leave it white (which is slightly translucent)
    -Guaranteed to fit perfectly.
    Sorry there isn't a closer picture installed. I no longer own the car that the panel is installed in, and that is the best picture I have of it installed. Hopefully I'll get a closeup soon.
  • Screaming_bmwe30
    • 128
    Number left:
    2"/50mm-------------18
    2-1/16 /55mm--------11
    2-5/8 /66mm---------9
    • JRKOUPE
      • Dec 2004
      • 3159
      plates
      hmmm......very nice....hmmmm
      so on the blk textured ones....is there still a paper protected side that remains white?......or?.....Im a bit confused on that.
      • s52e368
        • 539
        nice thing you got going.
        • Mike325
          • Mar 2006
          • 3685
          Agreed, I like your idea
          Originally posted by Kershaw
          • Screaming_bmwe30
            • 128
            The black textured ones have the backing removed, since the "face side" is painted. The back side of the panel is the side the lazer cutter cuts from, and also inscribes the gauge size into (for my reference), therefore this is the unexposed side, and already has the paper removed before cutting.
            If you were thinking of the reversability....the plastic is semi translucent, so when painted black, it has a tint on the white side. This also gives you the option of purposefully putting a tint on one of the sides to give it a whole new accent or effect.
            • Screaming_bmwe30
              • 128
              2-1/16 /55mm--------9 left
              • Screaming_bmwe30
                • 128
                2-1/16 /55mm--------7 left
                  • 37825
                  Sent you a PM
                  Classic BMW Specialists
                  Santa Clarita, CA
                  www.BimmerHeads.com
                  • Screaming_bmwe30
                    • 128
                    All paid orders have been shipped, and all emails have been replied to.
                    These are going fast, and I won't be able to get anymore lasercut until Mid january, so get em while they last.
                      • 37825
                      Payment sent.
                      For those that don't know Josh, he is a great seller to deal with and has been in the past aswell.
                      Santa Clarita, CA
                      www.BimmerHeads.com
                      • Screaming_bmwe30
                        • 128
                        Gauge panels left:
                        2-1/16-------6
                        2-5/8--------7
                        2"-----------18
                        • 155///MPH
                          • 473
                          Any way you would make one for the center vent hole?
                          DE's are a tease.
                          Build a racecar.
                          • Rennsport
                            • 2139
                            nice product here. fit perfectly, and looks awsome!!! i defenatly recomend these!
                            m106 1990 e30
                            e36 daily
                            e32 cruiser
                              • 37825
                              You should post up an installed pic!
                              Santa Clarita, CA
                              www.BimmerHeads.com
