Everything is OBO
m42 Longblock Recently rebuilt motor, Trans has new Clutch and seals, BMW reman starter, New Bosch Alternator, New AC compressor. Reciepts for all work can be provided. Also I have video of the car running and driving. Looking for $1,500+ shipping for everything, also can throw in any other thigns you need here and there.
5 speed swap parts (minus trans and Driveshaft) $200
Rear subframe- $100
Front rotors- $35
rear rotors- $40
Passenger door complete Brillantrot- $150
Driver door Brillantrot stripped- $100
Air Bag Knee Bolster (All 3 pieces) $65
Late Model Tails (Excellent condition)- $75
IS Trunk Spoiler (brillantront, paint flaking)- $45
318is ecu 175- $60
ABS Pump- $75
318is Master Cylinder and resevoir- $40
Sunvisors (Excellent Condition)- $30
Tan Kick Panels- $35
Brillantrot Electric Mirrors (One mirror has bubling on underside, not visible on car)- $75
Glovebox (no latch)- $40
Sunroof Crank- $30
m10 Intake manifold- $40
m10 Distributor, cap, rotor, wires, coil- $55
m10 Fuel rail with injectors- $40
m10 Throttle Body- $20
m10 PS pump- $30
m10 Alternator- $35
m10 Piston with Con rods and caps (3 avl) $25 each
m10 HP22 Auto Trans (108k) $100
m10 Upper oil pan- $60
m10 Lower oil pan (small dent)- $35
m10 Timing cover- $15
m10 afm- $30
6 button OBC- $30
m42 intake boot- $30
ABS computer- $30
Airbag control module- $45
91 318is gas tank- $100
4.10 open Small case (103k) $150
318is Drive shaft w/ new CSB and Guibo- $150
318is rear subframe- $75
318is front Calipers ATE(replaced recently)- $60
318is Rear Calipers ATE- $50
318is Spring set $80
318is Front Sway bar- $50
318is Rear Sway Bar- $40
Rear BOGE TURBO shocks (recently replaced, no leaks)- $50
wiper stalk- $25
turn signal stalk- $25
Rear View Mirror-$20
Sunroof panel for manual sunroof- $50
Passenger Door Seal- $35
93 m50 blck- $100 needs to be hot tanked
93 m50 vanos cams- $75
93 m50 crank- $100
m50 piston set- $80
m50 Con Rod set- $100
m50 lifter set- $50
m50 spring set- $50
s50 lifter set- $75
s50 valve set- $75
m50 coilpacks (6)- $75
m50 ac compressors x2- $60 each
I have alot of really good glass too....if you need glass.... I got it.
more parts to be listed...check back...or pm me if your looking for something.
Rear subframe- $100
Front rotors- $35
rear rotors- $40
318is ecu 175- $60
ABS Pump- $75
Sunroof Crank- $30
m10 PS pump- $30
m10 Alternator- $35
m10 afm- $30
6 button OBC- $30
ABS computer- $30
wiper stalk- $25
93 m50 crank- $100
m50 piston set- $80
m50 lifter set- $50
m50 spring set- $50
s50 lifter set- $75
s50 valve set- $75
