Stuff without pictures:
-Fan clutch with decent blade (15K miles on clutch always stored upright)..........25$ shipped
-325i expansion tank. Cheap fix for a leaking one, or to paint without having any downtime. 15$ shipped
-New 325i motor mounts & used good tranny mounts .................. 20$ shipped for motor mounts ......... 10$ shipped for tranny mounts
-Used Guibo's in good condition, perfect spares for turbo cars that regularly go through them. No cracks. .............10$ shipped each (2 available)
-Manual sunroof crank gear assembly (part that the crank handle attatches to...............15$ shipped
-Fuel injector electrical harness with perfect connections, and no corroded wires (a common problem on e30's).........15$ shipped
-325i Airbox's. Good for switching back to stock airbox from a cone filter. Filter not included in box...................20$ shipped each (2 available)
-325i fuel rail. perfect for custom modifying, or installing an extra set of injectors for tuning purposes......................20$ shipped
-325i exhaust manifolds with 1500 degree paint (already cured on engine) ...............................35$ shipped
325i crank wheel. perfect for welding pickup wheels to or grinding down for use with Standalone engine management programs (megasquirt, VEMS)...................30$ shipped
42# Lucas style injectors (have the fastest opening time of any type of injector) with low miles. I ran them for about 6K miles, and the person i bought them from had only used them for 5k miles on a V8 ford. I sold the turbo setup that I was using these to support. I was making around 300whp, and the injector duty cycle was around 76% at power peak running stock fuel pressure while using megasquirt. They are very clean, with good o-rings and they come with all of the plastic protective caps.
-42#/hr at 2.5bar fuel pressure
-Lucas style disk type outlet (fast response)
- ~10k miles of usage
$200 shipped
M20 Valve cover with High temp wrinkle paint. Looks awesome, and perfectly uniform wrinkle. Just an extra valve cover that I sanded and painted awhile ago to put on my m20, but no longer have a car to put it on.
$75 shipped
This is brand new besides a few scratches, so i'm selling it for what I bought it for not including the shipping costs I originally paid. This unit can probably accomodate 300+ hp in cooling efficiency, and probably has acceptable pressure drop taking into account it's internal volume.
--Good unit for mounting behind kidneys (with some modification) or using as a large side mount or front mount..
--12x12x3" core
--Bar Plate construction
--2.5" in/out
--has 4 little bolt holes welded onto core top and bottom for mounting
$100 shipped
5" Autometer autogauge tachometer. Has mounting hardware. Great for drag or road race when you need a bigger gauge face, and a shift light.
- 10K rpm
- Adjustable Shift light
- mounting bracket included
75$ shipped
Stock 325i/is/ix U.S. gauges from my 325i with 181K miles. Pending Money order payment
Mint 325i taillights. SOLD
"173" ecu from a '89 325i. Check the bottom of your ecu to make sure the numbers match. This was my trusty backup ecu for troubleshooting purposes, but I now have 3 of them, so i selling one since i don't need that many.
$40 shipped
Good working Master cylinder with Brake booster off my '89 325i. SOLD
Set of 325i pistons and rods. SOLD
Clean Auto transmission from an '89 325i (this 325i had 125K miles on it). Tranny lines to radiator were leaking, so instead of fixing, i just removed this tranny, and did a manual swap to the car. I have the auto driveshaft as well if needed.
Pickup only (Cincinnati, OH 45220)
25$ (need this gone bad before I move)
Reference Sensor for 325i. SOLD
2.5 bar Fuel pressure regulator. Great for letting the ecu adjust to larger injectors, or replacing your FPR on an eta motor. I use the 2.5bar regulator whenever i'm running 24# injectors with stock electronics
20$ shipped (1 available)
$200 shipped
$75 shipped
--12x12x3" core
--2.5" in/out
$100 shipped
- 10K rpm
75$ shipped
$40 shipped
