Haltech E8, Innovate wide band, stroker, misc M42 parts, CNC work
  • kishg
    • Sep 2006
    • 2624
    Originally posted by Eric
    I need a spacer that goes between the top underside of the strut tower and my ground control camber plates so the 4 bolts that allow for camber adjustment are no longer limited in travel by the strut tower.
    i'd be interested in that too..
    '12 F30 328i Sport Line
    '91 SpecE30 #523
    '00 Ford F-350 Dually Tow Vehicle
    BMWCCA #360858 NASA #
    128290
    • kowalski
      • Jan 2005
      • 1791
      as i said before, a little more explination on what ur talking about would be beneficial...
      • Eric
        • 5138
        I would rather not cut into the factory sheet metal on my M5. on my $1000 E30, sure why not.
        currently with ground control coil overs the camber adjustment has 4 bolts that are used to mount the camber plate to the main bearing. these bolts are about even with the top of the strut tower hole. a spacer slightly taller than the height of the allen bolt head would allow you to adjust camber to the desired degree, tighten the 4 bolts up, then slide the caster back to the desired spot.
        • kowalski
          • Jan 2005
          • 1791
          so basically your looking to raise the mounting point of the plates so that you have more room to angle the shocks? I did not mean cut into the sheet metal of the shock tower, i mean you could purchase some sheet metal, say about 5 inches by 5 inches, and drill some holes in it and you've basically got what i could machine you unless you want some fancy design on it, and to make it look nice... or i'm completely off in my guess as to what your looking for... I think if you snapped a picture and posted it up and did a little sketch on it of what you want would be a good way to let me know what your looking for.
          could also be that i've had 5 hours of sleep in 4 days...
          • kowalski
            • Jan 2005
            • 1791
            up
            • kowalski
              • Jan 2005
              • 1791
              bump
              • Eric
                • 5138
                pretty much i just need a spacer between the camber plate and the strut tower, but i don't want some hack job on the M5, i'm trying to keep the car looking somewhat presentable!
                I was thinking of just getting a few old shock towers and stripping them down since they already have enough room in the center for adjustment and the holes are lined up, but again i want the car to look well done
                • kowalski
                  • Jan 2005
                  • 1791
                  if you take some measurements and the thickness of the piece i can get back to you on that.
                  • Court M3
                    • Jan 2004
                    • 6713
                    got a set of clear euro smilies for trade if you still have the smoked.
                    Continuous For Sale Thread
                    323i s50
                    • kowalski
                      • Jan 2005
                      • 1791
                      i do still have the smoked. a lot of people pm'ing me about them but noone has commited... Send me pictures and we'll go from there.
                      • kowalski
                        • Jan 2005
                        • 1791
                        up
                        • kowalski
                          • Jan 2005
                          • 1791
                          buy my shit now dammit.
                          • kowalski
                            • Jan 2005
                            • 1791
                            up.
                            • kowalski
                              • Jan 2005
                              • 1791
                              up.
                              • kowalski
                                • Jan 2005
                                • 1791
                                bumparo?
