FS: M20B20 engine parts.
  • Jordan
    • 12912
    Here is the last of the good parts from this engine. Some would make excellent spares as these cars are rare state side.
    Valve cover, Roundel type. $20 (not pictured)
    Mechanical fuel pump $10 (not pictured)
    Complete engine wiring harness with transistorized ignition module $50 (not pictured)
    Piston set, 6, 9.8:1? CR with the 200 (eta) head. $50 (not pictured)
    m20 e21 engine mounts $25 SOLD
    Carburetor intake manifold $100 SOLD
    4 barrel SOLEX carburator. Clean and mechanically in good shape. I'm sure it needs a rebuild after sitting for years though. $50 SOLD
    Mechanical distributor with front timing case cover. Good spare, or conversion kit for cam driven distributor m20's. $65 SOLD
    200 head casting. Appropriate for m20b20, and e30 eta direct fitment. Other applications possible. Casting is clean, valves look good, springs/retainers/etc don't look great. Consider them free... or I can remove them if you like. $80
    Additionally! To items which the process applies, I can offer the parts glass bead blasted for a nominal additional fee.
    https://mtechniqueabs.com/
  • Jordan
    • 12912
    Bump
    • aaron.j
      • Jan 2006
      • 529
      ill give you 100$ for the head shipped to 28584
      • aaron.j
        • Jan 2006
        • 529
        nm was thinking this was the 731. forgot the casting number
        • Dominic49
          • Feb 2007
          • 1373
          does the intake mani bolt up to an m20b25?
          • Jordan
            • 12912
            It would yes, but the ports are the same size as an eta. Either way it sold this morning, sorry.
            • Ruffian
              • 378
              Heya J, is the front timing belt cover sold with the distributor? Also, on that m20, the water hose that runs from the water pump to the thermostat housing has just two 90 degree turns as the hose runs in front of that cover. Do you have that hose in good condition? (on newer m20's, as you know, they added the cam driven distributor and had to reroute that hose up, over and back around into the thermo housing.) Weird thing is that they didn't change the angle of those respective water necks on the housing or the water pump, but rather just redesigned the hoses, which produces some fairly tight bends in hoses, which is never a good thing. It would also eliminate how some people have the fan that eats that corner on that hose when the hose is re-installed without the proper routing and bracket.
              Keith
              "Die feine Art, schnell zu sein."
              "I don't have a gambling problem, my gambling pays for my e30 addiction."
              • Jordan
                • 12912
                The timing belt cover is still available. None of the hoses on this engine were salvageable, after sitting for 5-7 years.
                • Ruffian
                  • 378
                  price for the cover shipped to 95458. TIA
                  Keith
                  • Ruffian
                    • 378
                    Additionally, On the end of the camshaft, on that m20, there was/should be an adapter that allows for turning the cam from the outside of that cover. Do you still have that part? p/n 11311276855(according to realoem) Huge benefit when it comes time for doing the valve adjustment.
                    Keith
                    • Jordan
                      • 12912
                      $15 for the cover... and not sure what part you are talking about, that number isn't coming up for me.
                      Edit. Nope, was never there.
                      • Ruffian
                        • 378
                        Sold. paypal info?
                        Keith
                        • Jordan
                          • 12912
                          JSarette at Comcast dot net
                          • Ruffian
                            • 378
                            Sent, YGPM
                            Keith
