$700 takes the car.
1991 325i. 113k miles. Granitsilber Metallic.
Exterior:
Not much salvageable sheet metal left on the body. Maybe the front valance.
Factory mudflaps
Sealed Beams
Front Grill
Cracked Fogs
Suspension All installed 3k miles ago:
Rouge Eng. Rear Shock Mounts
AKG Motorsport Control Arm Carriers
Lemfoerder Control Arms
IE Polyurethane Trailing Arm Bushings
IE Polyurethane Subframe Bushings
Strut Housings with Turner Motorsport Brake Ducts and M3 Sway Tabs
M3 Sway Links
Wheels/Tires:
BBS RZ 15x7 et20
Toyo R888 235 50 15
Less than 500 miles
(For $50 extra I will roll/grind your fenders to fit these)
Ronal R8 14x6 et40? Black
Hankook iPike 175 70 14
Less than 4000 miles
Interior:
Stock Mint Black Vinyl Nonsports. Full Set
Leather with 1ft Slit in the Seatback. Rears Only
Mint Grey Plaid Cloth Sports Imported From Germany. Fronts Only
All stock interior parts. Very Clean.
Grey carpet
Noncracked dash
Crank sunroof
etc.
Drivetrain:
Open Diff, unsure of ratio. Redline fluid 5k miles ago.
5spd. Redline fluid 5k miles ago.
M20. Timing belt at 97k.
Misc. Will sell these separately.
Current Gen V1. Mint. $375. I can help you hardwire this into the check panel.
Uniden PC78 Elite CB Radio. I can help you hardwire this too. $70
Little Will Mag Mount 36in CB Antenna $35
With the above electronics you are pretty much untouchable on the freeway.
Exterior:
Factory mudflaps
Sealed Beams
Front Grill
Cracked Fogs
M3 Sway Links
Wheels/Tires:
BBS RZ 15x7 et20
Toyo R888 235 50 15
Less than 500 miles
Interior:
Grey carpet
Noncracked dash
Crank sunroof
etc.
Drivetrain:
