<FS> Various E30 parts...mounts/bushings, misc
    I've got the following E30 items for sale, condition as noted. Prices do NOT include shipping from 48116. Cheers.
    1. Aluminum motor/trans mounts, brand new in package, never used, sell as a set, $85
    2. Aluminum diff mount, also new in the package, $45
    3. Ground Control spherical bearing control arm bushings installed in the brackets, used but in fine shape, brackets included, these are offset, $200
    4. Single euro 9.4CR piston in +0.5mm overbore size, no rings, piston only but it's brand new, OEM Mahle, $75
    5. For M50 motor conversion folks: pair of S50 cams removed from an M3 LTW with ~28k miles on them, good shape, clean, $400/pair
    6. Set of brake caliper repair kits. 2 kits for the front Girlings and 2 kits for the rears, $40
    Probably have more later but this is a good start. Cheers.
    Jack Money
    http://www.Elephant Motorsports.com
    >> AST 4100 for BMW E30 $1649 <<
    AST Monotube Dampers and Coilover Kits - Full Service Dealer
    Schroth Safety Products Distributor
    BMW Replacement Parts - 24/7 Secure Online Ordering
    Update and bump....I've got the following E30 items for sale, condition as noted. Prices do NOT include shipping from 48116. Cheers.
    6. Set of brake caliper repair kits. 2 kits for the front Girlings and 2 kits for the rears, $SOLD
    New item: Turner spherical bearing rear shock mounts, brand new, for use with Bilstein or stock dampers (not Koni)...$200 includes new gaskets too
    Jack Money
      ygpm on cams
        5. For M50 motor conversion folks: pair of S50 cams removed from an M3 LTW with ~28k miles on them, good shape, clean, $400/pair PENDING
        7. Turner spherical bearing rear shock mounts, brand new, for use with Bilstein or stock dampers (not Koni)...$200 includes new gaskets too
        Jack Money
          5. For M50 motor conversion folks: pair of S50 cams removed from an M3 LTW with ~28k miles on them, good shape, clean, $SOLD
          Cams are sold.
          Jack Money
            More parts added!!
            8. M Coupe/Roadster diff bushing, brand new, pushed out from new cover for aluminum bushing, never used, $30
            9. E30 convertible tonneau cover shocks, brand new, never used or installed, brand is Stabilus (OEM), $65/pair
            10. Mintex 1144 front pad set, these are track pads not street pads, brand new, similar to Porterfield R4, $95/set
            11. Pair of rear tow hook/tie down thingys, these are the ones that bolt onto the lower shock attachment point and have a large eyelet for tie downs, brand new, never used, $40
            12. Set of 12 1st oversize valve guids (OEM TRW brand), size is 13.15mm, brand new, never used, these are for eta motors only, $40
            13. Main bearing set, brand new, never used or even opened, standard size, brand is Glyco (German, a BMW OEM brand), for e/i motors built through 2/88, $70
            14. Split Second ARM1 Air/Fuel meter, brand new, never used or installed, new in the box with all parts and instructions, $135
            15. OMEX programmable sequential shift light, model is Shift Light Sequential, brand new in the box, never used or installed, $150
            16. '95 M3 factory front spindles, brand new, one each L/R, sold as pair only, no bearings/struts, they are the spindles only, $350/pair
            17 Set of (6) NGK high power spark plugs, model BKR6EQUP for M/S/50/52/54, MINI, plus most V8 motors, brand new in the boxes, never used, $50/set of 6
            18. E30 convertible built thru 4/89 trunk shock, Stabilus brand (OEM), brand new, never used or installed, $25
            19. (4) Original BMW strut collars, the threaded collar that keeps the front strut inserts in the housings, brand new factory parts for use with factory shocks (I don't think these will work with Bilsteins but possibly with Koni's), $20/pair (2 needed per car)
            Jack Money
              Jack Money
                Does this come with the EGOS???
                Do you want to sell that alone if it does??
                  It is only the ARM1 so there's nothing additional other than instructions and some hardware.
                  Cheers.
                  Jack Money
                    1. Aluminum motor/trans mounts, brand new in package, never used, sell as a set, $SOLD
                    2. Aluminum diff mount, also new in the package, $SOLD
                    11. Pair of VAC rear tow hook/tie down thingys, these are the ones that bolt onto the lower shock attachment point and have a large eyelet for tie downs, brand new, never used, $40
                    12. Set of (12) 1st oversize valve guids (OEM TRW brand), size is 13.15mm, brand new, never used, these are for eta motors only, $40
                    17 Set of (6) NGK high power spark plugs, model BKR6EQUP for M/S/50/52/54, MINI, plus most V8 motors, brand new in the boxes, never used, $SOLD
                    Cheers.
                    Jack Money
