I am selling off all of my BMW E30 stuff. I am getting a newer M3 and
no longer need to hold on to this stuff. Some of the stuff I used on
my 89 325i and some I never got around to installing. I have pictures
of some stuff but if you know what it is then there should be little
questions. It is all in very good condition so send me an email on
what you want.
-AC Schnitzer 16in rims and tires. 4x100 et25 with 225-45-16 tires.
Hankook ventus RSS (Z211) tires have about 1k miles on them and the
car had perfect alignment at the time. Perfect fit for any E30 and
very rare. Has a polished finish. $1400
- Ground Control Coil over springs and adjusters. They are used but
work well. 600/500lb springs $250 SOLD!!!
- Ireland Engineering exhaust headers. Full long length, made for the
m20 and never used or installed. Comes with the X over and has a o2
sensor port. $300 SOLD!!!
- Z3 M mufflers. I have both left and right of the z3 m coupe/roadster
mufflers with 20k miles. No rust or dents. Perfect condition. $300
- E30 m20 manual transmission. Shifts great, comes with shifter plate
and manual pedals if wanted. I might have a flywheel that I will throw
in if I do. $250
- Very rare euro M3 EVO gauge cluster for the E30. Has low miles (not
sure exactly but can find out when I go to my storage unit). $300 SOLD!!!
- Fuel tank. This fuel tank goes in tandem with the gauge cluster. It
is also a rare evo part that is from the factory. It sits in the rear
boot between the shock towers. I have all of the pipes needed and even
the factory trunk carpet that is molded around it to make everything
look perfect like it came that way. The clusters fuel gauge is
calibrated to use with this fuel tank so I would like to sell them as
a pair. $300 SOLD!!!!!
- Suspension Techniques Sway Bar Set. 22mm front 19mm rear. Adjustable
rear bar, polyurethane bushings, adjustable rear links and full
hardware kit. Comes with a complete front and rear turner motorsports
reinforcement kit. All of this is new never mounted or used. $350
- Alpina front offset strut bushings. Great condition, no cracks or
problems. Works well with a lowered car. $100 SOLD!!!!
- Factory E30 "IS" Sideskirts. They are new never mounted or painted.
It gives your car a little sporty look and are very rare. You can not
get them from the dealer anymore. $250
what you want.
in if I do. $250
