Interior light delay w/ auto dimming - w/ FREE OBC temp sensor - $42
  • george graves
    • 20003
    SOLD
    POST HERE IF YOU ARE INTERESTED AND I WILL MAKE SOME MORE UP
    And I'll include a OBC temp sensor replacement FREE.
    Works with both the 6 button and 13 button OBC.
    $42 +$4.75 shipping USPS priority.
    PAYPAL: george.graves@gmail.com
    (Youtube version here: http://www.youtube.com/watch?v=xjPSJVDmgaU)
    (note - newer version is not adjustable)
    It works just like newer BMW’s, when you close your driver’s door, it keeps the the lights on, and then slowly fades out over a period of about 30-45 seconds.
    It has an added feature that when you turn the key, it dims down the light quicker, so that you can start driving. Anyone that had driven a newer BMW knows this feature. It adds a really cool lighting effect, and is very useful at times. Like when you need to read a map real quick.
    - Over 150 happy customers!
    - Quality construction
    - PWM (pulse width modulation) design uses very little current, less then the stock relay
    - Custom printed circuit board.
    - Replaces stock relay
    - No cutting, no splicing
    - Installation only requires a Phillips head screw driver and a 8mm socket.
    - Bench tested to over 50,000 cycles with out failure, about 6+ years of normal use
    Here is a look "under the hood"
    - remove the drivers side bottem dash cover to gain access to the hood relase cable bolts (8mm) and remove the bolts.
    - Remove the speaker panel and the speaker.
    - Remove the two screws that is just below the speaker opening and reach into the speaker cavity and pull the bracket out
    - Remove relay, and plug in the new dimmer mod.
    - button it back up and you are done.
    QUESTION: How do I check to see if I have the stock relay?
    ANSWER: Don’t worry, you don’t have to take anything apart.
    Simply open your drive’s door, kneel down, and slowly and
    gently push in the black pin in your door jam (it’s on the car not the
    door), you should see your interior light go out when you do. Now do
    it a few more times slowly, and listen for a clicking sound
    coming from about where the speaker is. If you hear a click, you
    have a relay and are good to go. If you don't have the stock relay
    relay installed, all you need to do is splice 1 one. I provide complete
    instructions.
    QUESTION: "Does it require no extra modification for it to dim
    down quick when you turn the key or do we have to tap into the
    ignition switch?"
    ANSWER: No extra
    work, it is plug and play. remove the stock relay, and replace with
    this. ZERO cutting, ZERO splicing...
    QUESTION: Where exactly is the relay that it replaces?
    ANSWER: The stock relay is located below the speaker on the
    driver side foot well. Basically, you remove the kick panel, and then
    pull the speaker out, undo two screws holding the relay bracket
    and pull the bracket out from under the speaker cavity, replace
    the relay, and you are done.
    QUESTION: What happens if I don't have the stock relay, will
    this still work?
    ANSWER: Yes, you will need to splice two wires to make it work, when you paypal me request the non-stock relay version.
    BEFORE INSTALLING THIS PRODUCT YOU MUST AGREE TO THE FOLLOWING CONDITIONS: 1. YOU AGREE TO BE FULLY RESPONSIBLE FOR ANY MISTAKES, ERRORS, MATERIAL LOSS, PERSONAL DAMAGE, SECONDARY DAMAGES, CAUSED BY ANY CIRCUMSTANCES RELATING TO THE USE OF THIS PRODUCT. 2. YOU ACCEPT FULL LIABILITY FOR THE OPERATION AND USE OF THIS PRODUCT AND ANY VEHICLE HAS BEEN INSTALLED ON. THE ONUS IS ON YOU TO CAUTION OTHERS WHO MAY OPERATE THE ABOVE VECHILE. 3. AGREE TO COMPENSATE GEORGE GRAVES FOR ANY LOSSES DUE TO LEGAL ACTION BROUGHT AGAINST ME BY YOU AND OR ANY OTHERS WHO HAVE OPERATED YOUR VEHICLE FOR ANY REASON. 4. ALL DRAWINGS, PICTURES, DESIGNS, ARE COPY WRITTEN AND ARE THE INTELLECTUAL PROPERTY OF GEORGE GRAVES AND ARE NOT TO BE REPRODUCED. 5. NO WARRANTY OR GUARANTEES EXPRESS OR IMPLIED.
    Originally posted by Matt-B
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    You should have some more money now...
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • george graves
      • 20003
      Got it - thanks! I'll ship it out first thing on Monday.
      • Fidhle007
        • Oct 2005
        • 7209
        8 minutes, that has to be some sort of record?
        • bmracer19
          • Jan 2007
          • 216
          Im interested!!! And I have money just sitting around, looking for a new owner!!! LOL!
          I think im a bit too low........ :(
          • Fidhle007
            • Oct 2005
            • 7209
            George, is that you talking in the video?
            • george graves
              • 20003
              Yes - it is. Why do you ask? Do I sound like a douche or something? LOL
              • Fidhle007
                • Oct 2005
                • 7209
                No no, you actually sound like a fairly nice and affable guy. Not at all how I pictured you... :razz:
                • HST
                  • Jan 2006
                  • 757
                  I'm in if you make more.
                  Originally posted by KingB
                  Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                  • george graves
                    • 20003
                    Anyone else down for a group buy?
