Need a US check panel?
  • TDE30
    • 7042
    I have seven of them.
    Seven US Check Panels (sold separately):
    a. Check Panel 1 - Bosch unit, good shape, has an O2 sensor warning light (which I've never seen before.) $25.
    b. Check Panel 2 - VDO unit, great shape (almost scratch-free.) $25.
    c. Check Panel 3 - VDO unit, a few light scratches. $20.
    d. Check Panel 4 - Bosch unit, great shape with one noticeable scratch. $20.
    e. Check Panel 5 - Bosch unit, great shape with one spot of hot glue remains (~1 cm spot). $20.
    f. Check Panel 6 - Hella unit with white backing, quite a few scratches on face of unit. $10.
    g. Check Panel 7 - Unknown unit, in MINT shape (no scratches at all), unit does not have backing. $10.
    Photos for all check panels located here, sorted on left side of page.
    Let me know,
    - Trey
    E90 325i/6 (ZSP, ZPP, ZCW)
    E36 325i sedan
    E30 325i sedan
    Volvo 945T
  • ///M42 sport
    • 3952
    Happen to know which cars had this option (o2 sensors)?
    • george graves
      • 19997
      Bump!
      Wow - I had no idea that there were so many different check panels. And they are all interchangeable correct?
      Originally posted by Matt-B
      • ///M42 sport
        • 3952
        If they are interchangeable, does additional wiring need to be done for the o2 sensor? If not, I'm interested.
        • NOMAD
          • Feb 2007
          • 1502
          I have an SRS version too, so that's another version that is out there.
          '74 2002 - Build blog at
          nomads2002.blogspot.com
          • TDE30
            • 7042
            No idea about the oxygen sensor deal. I pulled that one out of an E28 and didn't notice any extra wiring, so my guess would be there's no wiring difference.
            Is there a wiring difference with the SRS check panels and the normal ones?
            - Trey
            E36 325i sedan
            E30 325i sedan
            Volvo 945T
            • TDE30
              • 7042
              Bump.
              - Trey
              E36 325i sedan
              E30 325i sedan
              Volvo 945T
              • TDE30
                • 7042
                ///M42 sport, are you interested in the O2 check panel? Let me know.
                - Trey
                E36 325i sedan
                E30 325i sedan
                Volvo 945T
                • TDE30
                  • 7042
                  Top.
                  - Trey
                  E36 325i sedan
                  E30 325i sedan
                  Volvo 945T
                  • NOMAD
                    • Feb 2007
                    • 1502
                    From what I've seen only 5 series had the O2 sensor showing. All check panels have slots for "SRS", "O2 Sensor" and "Overheat" on them but they are obscured by the black paint.
                    I'm thinking it is either the addition of a wire, or they all run through the same wires to the ECU which controls it? Not sure. If you don't have an SRS airbag model then i can't imagine your car will "tell" the panel anything. Same with O2 sensor. It'll just never light up. No biggie.
                    • TDE30
                      • 7042
                      Hmm, thanks for the info. Not sure if I mentioned it or not, but the O2 sensor check panel was pulled from an E28, so I guess that explains it.
                      So, NOMAD, do you think there is any wiring differences between a non-O2 and an O2 sensor panel? If the O2 sensor malfunctions on an E30, would the panel indicate it?
                      - Trey
                      E36 325i sedan
                      E30 325i sedan
                      Volvo 945T
                      • NOMAD
                        • Feb 2007
                        • 1502
                        dunno
                        it'd be cool though.
                        • TDE30
                          • 7042
                          These are neat, you know you need one.
                          - Trey
                          E36 325i sedan
                          E30 325i sedan
                          Volvo 945T
