I have even more stuff that I want to clean out of my garage. Let me know if you need pictures of anything or if you have questions.
Pictures and descriptions can be found HERE.
E30 Parts:
14" basketweave center caps - good condition - $80
Motronic 173 ECU - SOLD
M20 Alternator – nearly new condition (only 500 miles) - $80
E30 'is' Wiring Harness - SOLD
E30 325is Stock Springs - $30 OBO - Front and rear springs.
E30 325is Stock Sway Bars - $30 OBO - Front and rear sway bars.
E30 Upper Strut Bearings x2 - SOLD
M20 Valve Cover Gasket - $9 obo
E30 Premium Sound System Amplifier, Stock - SOLD
E30 Ignition Switch - $20
E30 Intake Boot - $16 - new
E30 Fuel Filter - $12 - new, Bosch
E30 Guibo/Flex Disc - $40 – new, Febi – not a cheap knock-off brand
E30 Trailing Arm Bushings - SOLD
E30 Brake light switch - $13 - New
E30 Spark plugs - Set of 6 - $12 - Bosch W8LCR spark plugs – NEW
E30 US plate filler - SOLD
E30 US headlights and brackets – make offer - good condition, rings painted black
E30 Rear brake lines – inner - stainless steel – Goodridge - $20 – new
M20 Engine seals – misc – ask for specific ones that you need
Hella high beam lens - $20
E30 window switches
E30 door handle surrounds
E30 stock brake booster - SOLD
Grey door pulls and map pockets
Grey sport seats and rear seats – local pick-up only, but cheap (driver seat has some tears)
Wiper and turn signal stalks
Stock ignition coil - good condition - $20
E36 Parts:
S50 HFM + intake boot + generic cone filter - $100
BMW V-Belt for M5x engines - $15 – New - PN: 11 28 1 437 475
M50 Temperature Sender - $20 – New - PN: 12 62 1 747 281
E36 S52 Fuel Rail - SOLD
E36 S52 Fuel Rail - $40
E36 M52 Cams - $50 – 65k
E36 Stock Airbox - $25
E36: 540i 3.5" HFM – SOLD
E36 80A alternator – SOLD
E36 120A alternator - $60
E36 OBD-I power steering pump – off an S50 - $50
E36 power steering hoses - New and used
E36 starter – very good condition – used - $50
Misc E36 coolant hoses – cheap with purchase
Pink top injectors - 21.5 lb set - used - SOLD
E36 S50 Coil packs – 1 set of six – used - $90 - PN: 1 703 227
OBD-I ICV x2 - used - $20 each
OBD-I S50 Throttle Body - used - $50
OBD-II Cam position sensor - used (45k) - $40
E36 M52/S52 Oil Pan - SOLD
ICV hose-to-manifold clip - yes, the one that always breaks - excellent condition
2002/M10:
2002 Rear window chrome locking strip - $35 - New
M10 Head - Make Offer – unknown condition
M10 Block - Make Offer – very low miles, but one piston has a ding from a valve
M10 Valve Cover Gasket x2 - $8/ea – New
M10 2 caps and 1 rotor - $20 for all – New
2002 Control arms x2 - $200 for both, genuine BMW – New
2002 Ball joints x2 - SOLD
2002 Tie rods x2 - SOLD
Plastic grill set
Alu grill black slats
MSD Blaster 2 coil – lightly used - $25
M10 starter – SOLD
M10 Pertronix Ignitor – $65 – New
2002 Tii water pump – SOLD
E12 brake caliper (for Tii brake upgrade) – passenger side only - $45 – New/Reman
3.91 LS diff – SOLD
Larger rear view mirrors x 2
Misc window gaskets (front, rear)
Window regulator
2002 Owner’s Manual
Mintex Red box pads - for 5 series calipers used in common Tii upgrade
Front wheel bearing set
Door handle gasket set
Bunch of misc parts - wiper stalks, door handle, vent window regulator
E30 Parts:
E30 window switches
E36 Parts:
2002/M10:
Plastic grill set
M10 starter – SOLD
3.91 LS diff – SOLD
Window regulator
2002 Owner’s Manual
