Parting out my convertible. Everything must go. Car took a slight hit in the front so lights, grill, hood, etc. are trash. Recent clutch and full suspension overhaul. Many newer parts. Car stored in heated/cooled garage for several years... until now. All prices do not include shipping unless stated otherwise.
Parts already sold:
SOLD - Front/rear cardinal seats
SOLD - Convertible top
SOLD - Wheels
Available parts:
Everything else.... including:
- Engine: 233K miles, burns some oil, but well maintained, recent timing belt... $300 (1 2 3)
- Diff: 3.73 LSD, great condition, no noises, Redline fluid... $200 (1 2)
- Right front fender: Black, original BMW part, top front bolt hole slightly torn, no other damage... $100 (1)
- SOLD - Convertible spec Bilstein Sports: Front cartridges (will disassemble) with newer mounts (if wanted), rears complete with newer mounts... $250 (1 2)
- SOLD - Convertible spec Eibach Pro-kit springs: Front and rear... $130 (1 2 3 4)
- NIB Laso water pump... $40
- NIB Behr 5 spd. radiator... $145 SHIPPED
- SOLD - Flywheel: single mass: excellent condition, recently resurfaced... $135
- SOLD - Driveshaft: 5spd. Great condition, new CSB, newer centering bushing... $100
- Third brake light: black, great condition... $30 (1 2 3)
- Car cover: used, tan, thick Evolution type material, soft, some dirt and stains, small tear, lock(no key), cable... $60 (1 2 3 4 5 6 7 8)
- SOLD - Oiler cooler: great condition, no damage...$80 (1)
- Power steering pump: pulley, bracket, good condition... $40 (1 2)
- SOLD -Control arms and lollypops: About 50k on parts, Lemfoerder arms (I think), Boge bushings, no problems, tight... $100 (1 2 3)
- Expansion tank: Excellent condition, recently replaced, cap, used sensor - condition unknown... $30 (1 2)
- SOLD -Drive axles: great condition.... $40/side (1)
- Washer tank/pump: great condition w/ pump.... $25 (1 2)
- Parking brake set: good condition with hardware.... $25 (1 2)
- Rear brake calipers: good condition, pads, sensor, guide pins, and hoses.... $45 (1 2 3)
- ABS hydro unit: very nice condition.... $30 (1 2 3)
- Idle Control Valve (ICV): great cond...$30 (1)
- Bosch ECU DME 173: excellent condition, never opened.... $60 (1 2)
- High output 170A Alternator for E30: with adapter and voltage regulator, excellent condition, paid $500 for it new several years ago...$200 (1 2 3 4)
- Starter: great condition..... $35 (1 2 3)
- SOLD - Sachs Clutch kit: several thousand miles on it.. almost new. pressure plate, clutch disc, release bearing and release arm (not shown) - all replaced at the same time..... $130 (1 2 3)
- SOLD - BavAuto floormats: black, very nice condition. normal wear on driver's side.... $35 (1 2 3 4)
- Power mirror switch: excellent condition.... $6 (1 2)
- Ashtray: slight melt mark left side, otherwise v. nice cond.... $5 (1 2)
- BMP high performance spark plug wires: Blue, excellent condition with pulse wire.... $80 (1 2)
- Rocker panel covers: nice condition.... $40 (1)
- SOLD - Underdash panel: ok condition, very usable.... $15 (1 2)
- Leather BMW case & manuals: very nice....$30 (1 2 3)
SOLD - Glovebox: Excellent condition with lock.... $30 (1 2 3)
- Kickpanel/speaker covers: very nice condition. driver's side has slight crack (see pict)...$30 (1 2 3)
- Center console/shifter panel: Great condition.... $20 (1 2)
- Strut housings: L&R, with wheel bearings, great condition.... $30/each (1)
Parts I have but still gotta list:
SOLD - Z3 shifter and linkage
SOLD - Trunk plastic trim
SOLD - Jack
SOLD - Antenna
Wiper motor
cowl covers
wiring harness
HVAC
Ac lines
horns
pedal set with newer clutch master
rear bumper shocks
power antenna
trunk carpet (minus back piece) - SOLD floor piece, still have others
door jamb trim
boot cover
trunk lid
airbox with AFM
fogs
brake booster
master cylinder
clutch slave cylinder
rear bumper rubber surround pirces
SOLD - dash
SOLD - steering wheel
AC Compressor
rear subframe
rear control arms
SOLD - mirrors
fuel pump
aux fuel pump
seat belts
cluster
SOLD - rear tail lights
trunk shock
fuel door
trunk actuator
SOLD - carpet
door/panel trim
SOLD - trunk seal
...+ more
Parts already sold:
SOLD - Wheels
Available parts:
SOLD - Jack
SOLD - Antenna
Wiper motor
cowl covers
wiring harness
HVAC
Ac lines
horns
rear bumper shocks
power antenna
door jamb trim
boot cover
trunk lid
airbox with AFM
fogs
brake booster
master cylinder
SOLD - dash
AC Compressor
rear subframe
rear control arms
SOLD - mirrors
fuel pump
aux fuel pump
seat belts
cluster
trunk shock
fuel door
trunk actuator
SOLD - carpet
door/panel trim
SOLD - trunk seal
...+ more
