Garage Sale Bonanza!!!!! Engine Parts, Clutch, misc, ect...
  • Richie30
    • Apr 2006
    • 112
    lots of parts for sale.. eta parts are from an 86es. Need to clear up garage.
    ***Local PICK-UP is encouraged!***
    524TD Turbo Manifold, Ported and Notched to fit I head and 38mm Wastegate. ---- $100
    325i Stock Oil Cooler --- $20
    Power Steering Reservoir--- $5
    325I coolant reservoir ---- $5
    Sachs Clutch 89 325i (~1000 miles) --- $50
    Eta Coolant Reservoir --- $5
    Eta Radiator --- $25
    Eta Head ---$80
    Eta Intake Manifold --- $40
    Eta Engine Wiring Harness --- $50
    Eta Motronic Ecu --- $15
    Eta Intake Box w/ MAF --- $40
    Eta Idle Control Valve --- $5
    Eta Throttle Body --- $5
    Eta Fan Shroud --- $5
    Eta Crank Pulley --- $5
    Eta Washer Fluid Reservoir --- $5
    M20 Distributor Cap Cover --- $2
    M20 Spark Plug Wire Cover --- $2
    M20 Intake Boots x 2 --- $10 each
    M20 Ignition Coil Wire --- $2
    Master Slave Cylinder off of 89 325i --- $5
    Rear Deck off of 89 325i --- $20
    Black Sports Driver Side Door Panel --- $15
    Black Ash Tray --- $2
    Hood Shock --- $1
    Tan Speaker Covers --- $5
  • TexasTerp
    • Jan 2009
    • 3541
    will the Turbo manifold fit an m20?
    stephenbrody.com
    • PhillyG
      • 754
      yes.
      • Richie30
        • Apr 2006
        • 112
        yes
        • Richie30
          • Apr 2006
          • 112
          Originally posted by Jaygo333
          Will the eta Radiator fan fit 325is? 88
          The shroud as well?
          FAN? sorry no fan only radiator. but if your question is if the "radiator fits" it should but you will need to change different hose set up.
          • Richie30
            • Apr 2006
            • 112
            lots of goodies
            • E30_fiend
              • Apr 2006
              • 7348
              I see a steering wheel but no price so condition of steering wheel and price?
              Taylor
              • jahnaboi
                • Oct 2006
                • 1742
                Bump. Where were you guys last night?!
                SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                • Richie30
                  • Apr 2006
                  • 112
                  Taylor
                  hello tyalor,
                  steering wheel, Good condition normal wear, no tears, just dusty. I will let go locally for $20
                  • Richie30
                    • Apr 2006
                    • 112
                    We left at 2 and got sleepy, plus my front low beam went out boo.
                    • norcalE30
                      • Dec 2008
                      • 932
                      hood shock works fine? ill take it if it does
                      Originally posted by kronus
                      pff, all of you are slow as hell anyway. Eta > all
                      • cleansti
                        • Nov 2008
                        • 113
                        will the ecu work with a 86 325es AUTOtragic? if so $20 shipped? might need harness and ICV too
                        • Richie30
                          • Apr 2006
                          • 112
                          ECU will work, $20 shipped, If you want the the harness and icv pm me so we can make an arrangement.
                          • Richie30
                            • Apr 2006
                            • 112
                            come pick it up.
                            • norcalE30
                              • Dec 2008
                              • 932
                              hahaha yeah... how much shipped up here?
