M52 Z3/E36 new build Turbo Motor and Turbo Kit for Sale
  • vettedude
    • Jan 2021
    • 2
    Fresh Built M52 Turbo Motor built to reliably handle 600+ hp. Over 6k just in parts and machine shop work.
    Steel block
    S54 cams
    New vanos
    CP pistons and Rods (stock compression)
    Built Head with VAC Motorsports valves and dual springs
    Crush ring Head Gasket with new ARP Studs
    No exhaust manifold
    Titanium oil pump shaft
    Stewart Performance High flow water pump
    Baffled oil pan with turbo bung
    Engine is built to take over 600hp and rev up to 10k. Decided to go different route. Engine is 100% runnable ready to be installed and run. Invoice for Pistons and Rods in attached Picture.
    Full turbo kit is also available for $3250
    Turbo kit description:
    Bmw E36 / Z3 Turbo kit M52 (Complete with ecu and injectors!!!)
    Custom built turbo kit fits e36 or Z3
    Dual ball bearing to4e 63 trim billet compressor wheel turbo, oil lines, oil pan with bung welded, cast manifold, custom built intercooler pipes powder coated candy red, down pipe , exhaust, intercooler, tial blowoff valve , tial wastegate, obd1 intake manifold already prepared for boost, kit made over 500 hp bottom mount setup for clean install includes tuned ecu and injectors. Kit was removed in working order just doing a different motor setup (moving back to NA).
    This is as close to a plug and play combination you can get. With a bit of elbow grease you can install a turbo ready motor and kit directly into your Z3 with almost zero additional parts.
    Link to Craigslist Add with pictures:
  • vettedude
    • Jan 2021
    • 2
    Just to be clear (sorry for the typos) it has S52 cams and a Cut Ring Gasket.
