I'm in the process of replacing/installing both front door latches on a car I just picked up, and I've found that both door lock cylinders are broken. I already have 2 sets of keys (door and ignition) which I'm not fond of, so I'm looking to buy a complete working and matching lock set if available.
Anyone have a whole set of good condition coupe door lock cylinders, ignition lock cylinder, trunk lock cylinder, and a matching set of keys for all of them?
Also looking for a factory radio wiring pigtail (I believe mine has premium audio, but I'm not sure since the PO hacked everything up and hard wired an aftermarket head unit in (and popped a ton of fuses along the way). I'd like to re-wire everything back to factory connectors, so I'd be looking for the head unit connector and probably 6" of the wiring behind it.
Also looking for the dash panel underneath the steering column and above the pedals (non airbag car) and the mounting hardware. Mine is missing everything, so I'm unsure as to how many pieces are normally there. Either one or two pieces, I'd need all of it regardless.
Thanks!
Thanks!
