WTB: Manual transmission for euro e21 w m20: Getrag 242 or 245 from e12
  • ColdAccord
    • 5926
    I’m in the process of buying a manual ‘79 euro 323i with a factory m20. It has a bad transmission
    Looking for a getrag 242 or 245 trans from e21 or e12. Depending on which I may need shift linkage and driveshaft.
    I believe I’m limited to those two transmissions due to the mechanical speedometer drive.
    Located in Buffalo, NY but don’t mind paying shipping
    Any referrals appreciated. Thanks
    Originally posted by blunt
  • rbmwiv
    • Aug 2017
    • 57
    Mabe you could try something like this and then you will have more transmission options. https://www.speedhut.com/Speedbox.html
    • ColdAccord
      • 5926
      Thank you, that’s an interesting product, looks like it might cost the same as a transmission though heh
      • e30austin
        • 15382
        FYI, you would want a Getrag 265 (CR or OD), but you would need the bellhousing from a 1982 528e and a custom driveshaft to make it work, as an E21 never had a Getrag 265 installed in it, from the factory (to the best of my knowledge).
        A Getrag 245 would be your best solution, IMHO, since it is what the car is supposed to have; you wouldn't have to do any custom driveshaft/shifting assembly. I would get on the E21 section of bimmerforums, since there are a lot of 323i guys on there. They would know where you could find a good unit, as they are pretty scarce, these days.
        Best,
        e30austin
        • ColdAccord
          • 5926
          Still looking for a trans. Here's a pic of the car
          • LJ851
            • 7918
            The M20 245 and the M10 245 are basically the same transmission except for the front transmission housing. A decent transmission mechanic can swap the front housing from your existing transmission onto a much more readily available E21 245.
            I sold all my M20 245s a few years back.
            Lorin
            The M30 is God's engine.
            • Richardbohr
              • Oct 2018
              • 42
              Hey I have a getrag 260
              Manual that came out of a 1986 325e. Will that work for you?
              • kronus
                • Apr 2008
                • 13014
                I've got a 245/11 dogleg that needs syncros. gears are fine. can ship.
                cars beep boop
                • ColdAccord
                  • 5926
                  The car has a getrag 242 4 speed in it currently, would be nice to find one of those. Or a 245, with driveshaft and shift linkage.
                  Someone mentioned swapping the bell housings, but these transmissions don't have a detachable bell housing, they are 1 piece
                  • e30austin
                    • 15382
                    Right, you split the case and swap over the front half. Voilà.
