I was re-installing the dash tonight (prepping the car for the track on oct 14/15) and i managed to completely destroy the turn signal stalk.
car is an 87 325is, march build date. It looks like i need 61-31-1-373-025 "SWITCH TURN SIGNAL, DIP-DIM CONTROL, ON BORD COMPUTER = YES"
this the comlpete plastic mount, lever, and _wiring harness_. I need the entire assembly. it screws to the steering column with 2 phillips screws, and it attaches to a wire harness block on the steering column down undre the dash. i need the whole thing, including the plug connector. it should come out of a parts car in under 5-10 minutes (pull lower fascia, pull steering column trim, pull steering wheel, remove harness)
It looks like this part is the same across all E30s (with OBC and without airbag) so anyone with a parts car or even a local E30 in a junkyard should be able to help out. Unfortuneately i have neither at my disposal.
The key is - I need it ASAP. Literally, overnite or 2-day shipping is required. I _must_ have functioning signals or i will not pass tech inspection.
If anyone knows if I can use 61-31-1-377-966 (doesn't say +airbag or +obc), i.e. a switch that doesn't function for the OBC as a direct-plugin application, i am also willing to consider that one
Please email me at matt@mattevans.org, or call 701-361-1940 if you can help. I can paypal within hours.
