WTB: late model turn signal female connectors 2x
  • Schneider325
    • May 2004
    • 3818
    You would just need to cut the turn signal connectors off of your parts car (late model E30) with enough wire so I can soder them to my car.
    $5 shipped?
    Let me know
    Thanks
    Jon
  • Schneider325
    • May 2004
    • 3818
    bump
    • td325ic
      • Feb 2006
      • 773
      I believe the plugs are just over a dollar new, atleast that's what Pelican Parts price is.
      Part no # 61131378410 should be the correct plug if I'm not mistaken.
      Old used plugs are going to be corroded and the plastic tabs usually break off.
      I would buy new if you can.
      • Schneider325
        • May 2004
        • 3818
        thank you so much
        can anyone confirm that this is the right part or not?
        If
        • Schneider325
          • May 2004
          • 3818
          thank you so much
          If not Its still worth the money to see.
          • td325ic
            • Feb 2006
            • 773
            Here's a picture of the part you need, and the etk drawing of part #61131378410. They look the same to me so that should be the correct part.
            You know after thinking about it though, I'm not sure if buying new would be the easiest solution because part #61131378410 may just be the connector shell and not have any wire leads to splice into.
            So it maybe easier just to buy some used ones like you wanted.
            Anyway, I got two used connectors if you want them. Each one has about 3.5" of wire length. Both of them have a broken plastic clip but otherwise they are in ok shape, just a little dirty. PM me if you want them.
            • Schneider325
              • May 2004
              • 3818
              Why type of bumpers do you have?
              • Schneider325
                • May 2004
                • 3818
                wierd.. the turn single stocks I have, only have two prongs? Its from the metal euro bumpers, which i thought was the same as face lift plastic bumper turn signals. But the picture you show has holes for three prongs.
                • td325ic
                  • Feb 2006
                  • 773
                  The connector in the above photo was pulled from a late model, plastic bumper turn signal.
                  I know the turn signal lens is the same for both plastic bumpers and euro bumpers but maybe the turn signal housings are different. I can check tomorrow for you if you'd like.
                  I assumed that you were upgrading from diving boards to plastic bumpers and that's why you needed the late-model turn signal plug. Is this not the case?
                  • Schneider325
                    • May 2004
                    • 3818
                    Driving boards to euro bumpers. I just thought they had the same housing as plastic bumpers so I was looking for those connections.
                    I've been running connections from radioshack for the past few months but I want to get the correct connections so I can take the bumpers off and to a little work to them.
                    That would be awesome if you could check that out for me.
                    Greatly appreciated man
                    Thanks
                    • Schneider325
                      • May 2004
                      • 3818
                      bump
                      • joshh
                        • Aug 2004
                        • 6195
                        After reading this....what exact part do you need??
                        "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                        ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                        • Schneider325
                          • May 2004
                          • 3818
                          Early E30 euro turn signal stalk connection fitting. I thought it was the same as the late model plastic bumper E30 turn stingal stalk connection fitting, but I think I am wrong.
                          Anyone????
                          • td325ic
                            • Feb 2006
                            • 773
                            Hi, sorry for not getting back to you sooner. Here's a photo of the plastic bumper turn signal and the euro bumper turn signal. You can tell from the pic that the connectors are obviously different.
                            I looked on realoem but couldn't find the connector for the euro bumper turn signal. Unless someone else can come up with a part number I think you're stuck with just rigging up something. That would probably be the easiest way anyway.
