Spacers and Adapters....100% custom
  • jeffw
    • 1087
    #151
    hmmmm..... I'll have to look into it a bit i'm not sure
    • z31maniac
      • 17566
      #152
      Hmmmm, this has me considering some high offset RS. 17" 5 lug RSs are pretty widely available and pretty affordable.
      What would be the largest adapter you'd want to make, thickness wise?
      www.gutenparts.com
      • B2ThaZiZza
        • Aug 2004
        • 614
        #153
        im interested in some 5x100-5x120 toyota 54.1mm centerbore
        • zack.dawley
          • Dec 2009
          • 1
          #154
          Sent a pm, but I need 45mm spacers for my E34. You will make my month if I can still get these.
          • e30Rob
            Master of Adaptation
            • 1182
            #155
            Back up and running.....from now on they will be shipped per order rather than a GB!!
            Need Custom spacers and adapters?
            PM for information
            • e30Rob
              • 1182
              #156
              They can be had with a pritty decent size...just depends on what you want
              can be done no problem
              at this thickness you would have to go adapters....5x120 to 5x120....there arent lugs long enough to fit through a 45mm spacer. However if you want that thickness and source your own hardware that would not be a problem. Price would increase slightly due to the amount of material used.
              PM for information
              • sharky
                • Jan 2005
                • 2672
                #157
                If someone can assist me with what sizes I should use running 16x7 Alpinas w/ 28et on 215/45 16's and a 87 is then I would be in for a whole set. I want to push the wheels out a bit to get them a bit more flush, not looking for stanceworks poke or anything just something a bit more aggressive.
                • e30Rob
                  • 1182
                  #158
                  i personally would do a 10mm in the front and a 15mm in the back.
                  PM for information
                  • e30Rob
                    • 1182
                    #159
                    Check em out guys...where up and running again
                    PM for information
                    • Matt-B
                      The Waffler
                      • 3856
                      #160
                      ill most likely be in contact way before the picnic...
                      adapters are cheaper then redrill
                      • e30Rob
                        • 1182
                        #161
                        I'm not sure what picnic u might be talkin about but ok...lol
                        and yes adapters are cheaper than a redrill.
                        -Rob
                        PM for information
                        • Matt-B
                          The Waffler
                          • 3856
                          #162
                          e30 pinic is the PNW 200-300 e30s every year lol
                          so yea ill be in contact and i did look around
                          these are the best quality and best price. sorry about dickering with the price in the past
                          • e30Rob
                            • 1182
                            #163
                            It's cool man, i gots no hard feelings..lol I figured you would look around just like i suggested and find what you found.
                            Look forward to hearing from you.
                            -Rob
                            PM for information
                            • bimmer_E30
                              • 5001
                              #164
                              Do you have any 5mm spacers?
                              Originally posted by e30e
                              • e30Rob
                                • 1182
                                #165
                                Direct quote from the first page:
                                - Hubcentric spacers (sold as pairs)
                                - 3 to 8mm. $50.00
                                - 9 to 17.5mm. $65.00
                                - 18 to 30mm. $75.00
                                PM for information
