Spacers and Adapters....100% custom
  • e30Rob
    Master of Adaptation
    • 1182
    #556
    Originally posted by MatRacer
    What is the minimum thickness to get a 4x100 bmw E30 fitment hubcentric spacer?
    Thanks!
    13mm. This is the distance the e30 hub protrudes.
    To everyone else, all pm's replied. I have set up a little system to be slightly more proficient with the pm returning. Thanks for all your patience.
    -Rob
    Need Custom spacers and adapters?
    PM for information
    • MatRacer
      • 562
      #557
      All right!
      You got a PM!
      E30 now S52
      2008 Suburban LTZ (Family and TT hauler)
      325xiT (Sold)
      • Wild Ride
        • Apr 2008
        • 739
        #558
        PM'ed
        Basically I need something like this but 10mm to properly mount filled and drilled e38 style 5's.
        • simplyclean325i
          • Apr 2011
          • 259
          #559
          has to been asked plenty of times,
          suspension: bc coilover
          wheel size and tire: 16x9 offset 10 tires 215/40
          it's as low as i can go without rubbing the inside of the tire and still want more low, what do you say as for spacer, 3mm or even less?
          • N2MYE30
            • Oct 2007
            • 5536
            #560
            hubcentric rings 74.1 to 72.56. shipped price to 27615?
            COTM
            • e30lov
              • Jul 2008
              • 1597
              #561
              14mm 5x120 spacer with a 72.56 hub bore and a 70.3 wheelcentric
              17mm 5x120 spacer with a 72.56 hub bore and a 70.3 wheelcentric
              price with extended lugs shipped to 17522?
              `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
              • E30_fiend
                • Apr 2006
                • 7348
                #562
                You will clear with that setup and no spacers. On a 16x9, you need to be at at least et10 to clear the strut tube. Since youre already there, no need for a spacer to clear unless you want more poke.
                Taylor
                • simplyclean325i
                  • Apr 2011
                  • 259
                  #563
                  Taylor
                  The edges of the adjusters rub the inside of the tire, so i need to kick the wheels out a little to clear it to go any lower. would 3mm fix that perfect, and do you need new lugs or will the ones i have in fit fine? thanks man
                  • dantes
                    • Mar 2012
                    • 161
                    #564
                    need some adapters for 4x100 wheels are BBS rs025 16x9 et36,
                    please pm me
                    If you want to feel rich, just count all the things you have that money can't buy.
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      #565
                      3mm should get you clear. although, a 5mm would do the same and get you where you want offset wise. As long as youre pretty low, they should look amazing. The only other option besides spacers would be to dial the camber a bit more positive.
                      Taylor
                      • MatRacer
                        • 562
                        #566
                        Got my spacers last week.
                        The finish is really good and the tolerancing seems to be pretty perfect! The fit is really tight! as we all like.
                        Thanks for the great product!
                        Mat
                        E30 now S52
                        325xiT (Sold)
                        • einstein57
                          • Jun 2007
                          • 10780
                          #567
                          Need a pair of 5mm spacer/hubadapter with a 74.1 outer boar for my e39 style 5s
                          www.gecoils.com
                          • Songj91
                            • May 2011
                            • 211
                            #568
                            Hey please respond to my PM when u get the chance! PayPal ready!
                            Thanks!
                            • TrippinBimmer
                              • Feb 2011
                              • 182
                              #569
                              Need a set of spacer/hub adapter with a 56.1mm outer bore for my Civic SI 4x100 16x7 ET44 Wheels (Works Emotion). I would like it flush.
                              -Anthony
                              • Mr. Tasty
                                • Jul 2011
                                • 3421
                                #570
                                can you guys make 4x100 to 5x120.6 adapter?
                                2014 Alpine White 335i MSport
                                (Daily Driver)
                                Full Mperformance Aero
                                KW V2 Coilovers
                                VRSF Catless Downpipes
