Spacers and Adapters....100% custom
How about a 5-120, 8mm spacer for an e39 wheel to a regular/standard bmw 72.XX mm hub.
This way no F!@#ing hub rings. Specifically for those e39 style 5 two piece wheels that have a tapered backside?Originally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2002 325xit Sil/blk. SOLD
2010 F650gs twin
2016 M235i cabby. Mineral grey/Red leatherComment
Need Custom spacers and adapters?
PM for informationComment
Great!
So you can match the angle on the back side of the e39 two piece style fives, tapered down to e39 hub bore OD with e30 m3 ID?
If so, i will definately take a pair of 8mm and a pair of 5mm.
LMK.
do you have access to a style 5 rim to measure?
Cheers
ToddOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2010 F650gs twin
-RobNeed Custom spacers and adapters?
Yes....I already have them on my car now.
Problem is they are e39 hub bore, so i need thin piddly hub rings, that get damaged all the time, to keep from getting a shimmy.
I also need to run min 5mm spacer in the front to clear the caliper without removing the anti squel clips.(I run 5mm now but its not enough with new pads)
So now i have spaced the fronts, I want to space the rears, but there is more room in the fenders so i want to go 8mm.(I have 5mm now)
Now because the difference is so little in hub diameters, you cannot make a 5mm spacer with a hub centric adapter built on from 74.xxmm (e39) to 72.xx(everything else 5 lug) and have it not be flimsy. But... the style 5's have a tapered rear on the inner barrel, so I thought it may work if that was also used for allignment.
It would be great to get it all on one piece so its easier to install.
Simple ........right? LOLOriginally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2010 F650gs twin
/\ You know you can just use a grinder to to take some of the slip down right? I did it to mine and they work great.Comment
2010 F650gs twin
O you mean the anti rattle clips? yeah i could grind them down so I don't need spacers, but the real issue is the rings being so flimsy.
I was just hoping to get custom spacers with rings built in to go from regular bmw hub to e39 hub diameter to make wheel installs easier and rings stronger by including the extra meat with the tapered part.Originally posted by codyep3I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
2010 F650gs twin
