Custom CA Mounts for E30
  • IanS_in_Oz
    • Jan 2010
    • 75
    Hi all,
    I'm looking for expressions of interest in custom solid control arm mounts to suit E36 front suspesion legs in an E30.
    I designed these myself to cure the wheel positioning problem when fitting E36 struts to an E30.
    They are solid aluminium, with a Delrin bush for the control arm. The offset provided is much greater than the M3 ones, the PU ones, or even the Greentree Racing ones.
    When coupled with E36 M3 control arms, and standard E36 or M3 front spindles, these CA mounts position the wheel perfectly in the wheel arch.
    These pieces make an E36 five-stud conversion for an E30 a true bolt-on conversion, and allow you to fit E36 M3 brakes.
    They will cost around $250 per set, if I can get enough buyers to get a batch made. I have three potentials already.
    These are the best pics I've got, showing them fitted to my E30 M52 2.8
    Cheers
    Ian
    BumbleE30 M52 2.8i
    • 37832
    Damn, that's cool. I could definitely be interested.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • 240zs30
      • 583
      Ian
      [/quote]
      So this set up is with an e36 non m control arm? would be very interested as well.
      • mattdk318i
        • Jun 2006
        • 3953
        looks like it still requires the M control arms.
        • mattdk318i
          • Jun 2006
          • 3953
          "When coupled with E36 M3 control arms, and standard E36 or M3 front spindles, these CA mounts position the wheel perfectly in the wheel arch."
          • Dozyproductions
            • Jan 2007
            • 4682
            Wow, you might potentially open up a new wave of 5 lug conversions. Hats off to you!
            • rThor432
              • Feb 2007
              • 3907
              I'd be interested.
              • IanS_in_Oz
                • Jan 2010
                • 75
                Originally posted by 240zs30
                Ian
                It would work with Non-M control arms, but the wheel would sit a little further back. The M-control arms make the wheels sit exactly right
                Originally posted by rThor432
                I'd be interested.
                If you three guys are in, it might be just enough to get a batch made up.
                Do you want to go ahead?
                BumbleE30 M52 2.8i
                • Dirtsquirt
                  • Nov 2004
                  • 686
                  There are two sets of "M" control arms...
                  95MY and 96+
                  E30/standard E36 control arms are identical to 95 M3.... Except for the balljoints. E30 uses solid joints, standard E36 are rubber dampened and 95 M3 are solid hardened.
                  So I'm assuming these use 96+?
                  • Roysneon
                    • 4505
                    So maybe I'm missing something huge, but I' gonna buy these instead of the M3 spindles? Is that supposed to be cheaper? I'm assuming that is the benefit, right?
                    Originally posted by mbonanni
                    I am a pursit now.
                    • BMW_TUNER
                      • Jul 2006
                      • 1386
                      I would really like to see these compared to the Treehouse eyeballs? I am wondering how much more centered I can be with these?
                      1989 332IS -S-Fiddy Four-Some weight removed.
                      5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                        • 37832
                        No, these go along with the E36 5 lug swap to center the front wheel.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • IanS_in_Oz
                          • Jan 2010
                          • 75
                          This is part of a bolt-on conversion to E36 5-lug, so you can fit E36 M3 brakes, and std E36 offset 17" wheels and the wheel ends up centered in the wheel arch.
                          You can fit std or M3 spindles.
                          I think its around 20mm further forward. I didn't have thr treehouse ones handy to compare, but these move the back of the arm to within 1/8" of the chassis rail, and adjust for the angle of the arm as well.
                          95MY and 96+
                          Yes 96+ control arms are recommended, as they have a little more castor built in as well.
                          Ian
                          BumbleE30 M52 2.8i
                          • 240zs30
                            • 583
                            Interested but i'm not ready just yet. I've researched it to death and have acquired the M spindles, brakes etc. Just need the control arms which are the sticking point at the price and TRM mounts or these. Seems you might have enough interest for a GB maybe the price can come down if you get enough people.
                            • bzboardz
                              • 1096
                              im not ready for these yet, but bump for a good looking product
