JOM Coilover System Group Buy #3
  • Kvasi
    • Apr 2011
    • 1122
    #226
    Anyone with a 6syl 51mm kit that could measure the length on the front shocks?
    Wondering if i could make them fit my ix.
    • mightywhitey
      • Oct 2009
      • 985
      #227
      Originally posted by LagunengrunE36
      How did you guys install the front springs? What kind of spring compressor did you use? I rented one from O'Reilly's but it doesn't work.
      You probobly have the adjuster on the bottom installed upside down. Flip it so the threads go down and aroung the strut housing. You do not need a spring compresser to install the springs.
      1991 e30 328i M52 swapped: Gone
      1995 e34 540i/6 1 of 76 Clean
      1985 e28 euro 525i the daily
      • Schwarz325
        • Aug 2009
        • 487
        #228
        are bump stops required with this etups?
        • ck_taft325is
          • Sep 2007
          • 6880
          #229
          You shouldn't need one for the fronts, honestly.
          Need a part? PM me.
          • LagunengrunE36
            • 77
            #230
            Yep, I had the adjuster upside down. Thanks.
            • E30Rookie37
              • 308
              #231
              I got my vert kit!! The address on the box for shipping to me didn't match up at all but at least the mailman had my name and address and was able to figure it out. I got it in like 5 days. Super fast shipping!
              86' 325e
              Quote:
              Originally Posted by 02stu
              They're (e30s) very sensible if you never want to get laid by anything other then a college student..on second thought
              • randomsv650
                • Jul 2011
                • 614
                #232
                5 days? thats pretty ridiculous! im stoked to get mine when they're ready :up:
                • xikyle
                  • May 2011
                  • 526
                  #233
                  i really want a set but im dropping a motor right now. do you think this will come around again?
                  Originally posted by ApexGoblin
                  well make sure your priorities are straight... e30 first :up:
                  • randomsv650
                    • Jul 2011
                    • 614
                    #234
                    I think this is the 3rd or 4th group buy he's done, so probably. BUT, they have gone up in price each round (which makes sense).
                    • xikyle
                      • May 2011
                      • 526
                      #235
                      stupid monies. i guess when the time comes i will obtain low.
                      • Chrisv006
                        • 375
                        #236
                        So how is this kit compared to H&R Sports and Bilsteins?
                        I want something comperable to H&R OE springs for my 1991 318is, softer than the sport setup so I can have a comfortable DD.
                        • Zinno_e30
                          • Jul 2010
                          • 553
                          #237
                          Does anyone have the measurements on these coils? I am trying to order GC Camber plates and they can't find the appropriate spacer without the specs..
                          • Fair!
                            • Mar 2007
                            • 202
                            #238
                            I'm trying to answer some customer tech questions about these here, but not picking on these coilovers (biting my tongue in the process).
                            Originally posted by e30gentry
                            What camber plates will work with these?
                            Just had a customer call asking about Vorshlag camber plates for these $400 coilovers, so I thought I'd take a look at the thread. I asked him some questions about them, but the pictures here tell me a lot more.
                            He thought they came with standard "coilover" springs, but from looking at the pics its obviously a tapered spring made to work with the OEM upper perch, so it will need to use OEM style upper spring perch. Bilstein does this on some of their PSS9s, too. Since we supply new upper spring perches with our plates (BMW part with welded bearing ring, with press-fit sealed radial bearing and bushings matched to the strut profile), that's good to know. We do make an upper perch the OEM E30 spring (pictures shown below for clarity).
                            Since we build our spring perches to order, and there can be dozens of variations from strut brand to brand (with respect to strut shaft profile diameters/lengths/shoulders), so we'll need some shaft measurements to be able to make them correctly for these struts. Normally we just need to do this once, but since these are made where they are, I don't expect these measurements to stay consistent, so we'll ask each JOM customer to measure their set. We always do this for Chinese built struts, since the specs/dimensions (and suppliers) change often. Since all E30's used the same ID front OEM springs, at least that much is known (FWIW: there are 3 OEM spring inner diameter sizes for the E36).
                            Fair warning: our camber plates will cost more than this entire shock/spring set-up. That's "Made in America vs Made in China". Not knocking it, just wanted to warn people. Most people that buy $400 coilovers aren't buying camber plates, but sometimes it happens.
                            Originally posted by achtunge30
                            I realize the reviews so far have been good in terms of how low they can go, what about improvement in handling?
                            Really? I'll stop, I'll stop... :D
                            Originally posted by dinanm3atl
                            I usually use the Vorshlag/AST Rear Adjusters, Nylon Bottom mounts and their Hyperco springs.
                            Yea, we get these requests when people have shock kits without adjustable ride height platforms out back (or poor ones). For an E30 we sometimes use a 5.5" long spring, if ride heights are going to be kept high. Hyperco makes makes a 60mm ID spring in 3 different rates in that length, for us and AST. Lately on Z3s and E30s we tend to use a 5" long spring, for substantially lowered set-ups. Hyperco doesn't make a 5" long spring in 60mm ID, but they do make a 5" x 2.25" ID, in dozens of spring rates. We re-machine the AST ride height platforms on our lathe to accept the smaller 2.25" diameter rear springs, too.
                            Again, this set-up shown above of Hyperco springs/AST spring platforms/Vorshlag upper alignment platforms costs more than these coilovers, so maybe not a lot of interest in this thread. Just replying to that quoted shout out.
                            Yep, your will have to measure each diameter (in mm) and length of each step (inches or mm) and each diameter transition (45° taper or 90° square shoulder). GC will need to know this to make plates that fit, just like we would.
                            Good luck,
                            Terry Fair - www.vorshlag.com
                            Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
                            • dinanm3atl
                              • Feb 2007
                              • 7305
                              #239
                              Thanks for the reply Terry - I ordered a set to test out. I am interested to see how it goes and performs. Last E30 had a custom GC setup and my E36 M3 has ASTs. Worst case I sell them and run something I know. I like to experiment though :)
                              • Zinno_e30
                                • Jul 2010
                                • 553
                                #240
                                Can someone who hasn't installed these yet measure them?
