Someone should do a video demonstration of this alarm system, because im soo down to take out my viper system for this, seems to have a ton more options than what i have!
e30 Keyless Entry (Sold Out)
I just installed the "alarm" today soley as a keyless entry. I am having the problem with the auto-locking as well roughly 20 seconds after unlocking with the remote. other than that the system is working great.well definately cant condem it as defective till in know i have it wired/jumpered properly. so will wait for more info for sure ,definately think better descriptions of what to wire everything to is needed (exactly what signal every wire needs to see) will help as reading/deciphering the chinenglish manual is difficult at best ,almost feel like something has been lost in translation. maybe even a board level diagram? and maybe once a few others try installing we will see the common issues and solutions and i will know its not just mine...i seem to be the first to mention anything about installing this newest system so far
sure like the keyless entry function so far
I installed the unit in my trunk near the actuator.
Car Module
Brown - Ground - Black+Yellow+Black/Yellow
Green/Black - Lock - White
Green/Purple - Unlock - White/Black
Battery - Power - Red
I tried jumping the JP1, but that didn't help.
Any advice?
Isaac:: PNW Crew ::
'87 325 4dr, '74 2002Comment
well its not just mine that is acting up then ,thats good to know,Einstein is trying to reach tech support for my various issues as stated in a previous post (one of which is the auto-arming not stopping even when jumpered at JP1) but i haven't heard anything in days as to whats happening........Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
:)Comment
The JP1 jumper should remove the auto arm. If you guys can't get it to work I can exchange out the unit or refund your orders.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
I'll crack mine it open tonight, take a look at the PCB, and see what I can find.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
BUMP .....any news ,i just removed mine (left wiring installed )as to not drain battery down from flashing lights all the time. sure would like some answers
any chance of doing just a keyless entry with the E46 type keys????Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
:)Comment
It seems that they auto-arming funtion when you turn off the car can not be de-activated. If this is a problem please fell free to send back the units for a refund. Sorry for the let down.
You have to fully make sure the ignition, brake, and door sensors are wired in to prevent that from happening.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Yes. I gave einstein57 the info.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
www.gecoils.com
I discovered how to make the auto lock stop happening.
I removed the JP1 jumper that I had soldered in. What you need to do is momentarily short the blue wire (door signal) to ground. This can be accomplished by running that wire to any of the door/truck switches and momentarily opening and closing the door. I plan to daisy chain my four doors and trunk to the door signal wire so that it prevents the auto locking with any of my doors being open. When you do not open a door or the module doesn't see that momentary ground within the 20 second time frame it will still autolock.
If the door stays open (ground is constant) there is a relay that cycles on the unit, which according to the instructions is the lights flashing indicating that your door is open, which is not hooked up on my car. So, you don't want to permanently ground the unit or it will run your battery dead.
As an FYI I don't have the lights, horn, shock sensor, brake signal or ignition hooked up to this unit. I am only using it for keyless entry.
Hope this helps a lot of you guys.:: PNW Crew ::
