Full alarm functionality without auto locking
e30 Keyless Entry (Sold Out)
www.gecoils.com
I don't see why not. Just need to get the proper blanks. UAS sells some.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
no luck
well my attempt to use two diodes in the system to stop the backfeeding voltage on the accessories circuit and allow the the use of the pink wire to still feed the siren and allowing functionality of the alarm portion works great until the alarm is triggered (by motion sensor in my case),once triggered it will not shut off until unlock is pressed on the fob (alarm runs continuously in a loop thru all the tones),the pink wire is needed to pulse 12v on the white wire just as it tries to autolock ,but if the alarm is triggered the control see's that same 12v on the pink (siren blaring) wire as the ignition switch being on and so alarm stays triggered. dont know a way to get around this and dont think its worth the effort anymore . suffice to say if you want the auto locking to stop do as Einstein stated and connect the pink to white wire and use the unit as a keyless entry only , or use as and alarm just without the siren.(flashing lights only when triggered)
haven't decided how/if im going to finish mine up yet haven't had the keys cut yet and really wanted a working integrated alarm with the E46 style fob for keyless entry
ask any question you have and i will try to answer based on how i have it set up in my IX and what i have exprimented withLast edited by spdracrm3; 10-05-2012, 07:02 PM.Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
Originally posted by spdracrm3 View Postwell my attempt to use two diodes in the system to stop the backfeeding voltage on the accessories circuit and allow the the use of the pink wire to still feed the siren and allowing functionality of the alarm portion works great until the alarm is triggered (by motion sensor in my case),once triggered it will not shut off until unlock is pressed on the fob (alarm runs continuously in a loop thru all the tones),the pink wire is needed to pulse 12v on the white wire just as it tries to autolock ,but if the alarm is triggered the control see's that same 12v on the pink (siren blaring) wire as the ignition switch being on and so alarm stays triggered. dont know a way to get around this and dont think its worth the effort anymore . suffice to say if you want the auto locking to stop do as Einstein stated and connect the pink to white wire and use the unit as a keyless entry only , or use as and alarm just without the siren.(flashing lights only when triggered)
Originally posted by bmwstephen View Postwait so what's going on?? ur alarm is auto locking ur vehicle?
if you read thru all my posts on the last few post you'll understandAngus
88 E30M3 X2
89 325IX
92 R100GS/PD
Originally posted by spdracrm3 View Postthe E46 fob style kit from Einstein is and alarm system not just keyless entry ,and one if the quirks is that the system automatically tries to lock the doors after about 20-25 sec once unlocked with the fob , this is very annoying ,and we are trying to find a way to stop it. Einstein found out by connecting two wires it will prevent this from happening but it means the alarm system siren cannot be used . i was trying to find a way to maintain alarm functions but to no avail....
What i'm getting at is that the "problem" you are describing, is a pretty normal feature on most alarms when they are first setup. It's called passive arming (just like my scytek g20) and can be disabled via jumper settings or a certain clicking pattern.
yes once unlocked with fob it will relock in 20-30 seconds unless you connect (pink "siren" wire to white "on" wire) this is on the E46 alarm style system not the keyless entry only system. so dont leave keys in car with windows rolled up!
i will be on vacation for 10 days but when i get back will try to get a detailed description of how i have mine wired (been to busy lately to get to it )Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
Alright everything installed perfectly fine, but now I'm faced with a dilemma. I can't find anywhere to get my keys cut. The locksmith shut me down immediately and said they and nowhere else in the area cuts steel keys, and the BMW had no idea as well. Where can I get the keys cut? I didn't think it'd be this much of a hassle
Originally posted by CubbyChowder View PostAlright everything installed perfectly fine, but now I'm faced with a dilemma. I can't find anywhere to get my keys cut. The locksmith shut me down immediately and said they and nowhere else in the area cuts steel keys, and the BMW had no idea as well. Where can I get the keys cut? I didn't think it'd be this much of a hassleAlpha Team Inductee
2014 Icon E-Flyer
2013 Zboard San Francisco Special
2010 Buell XB9SX
2009 Harley-Davidson 883 Iron - "Xerces"
1991 BMW 362iS Touring - "Stephanie/The Death Machine 2.0"
1974 Honda CB360/CL360 Scrambler Project
1971 Honda Trail 90 - "Stephen Parish"
2008 Saab 9-3 Convertible
2002 Mazda Miata LS
Originally posted by OldDrunkenSailor View PostI had one of mine completely butchered. They then told me "Well, we couldn't get it right so we're not going to charge you for it." Really, completely destroy half of my blanks and you won't charge me? Thanks! Now I'm horrified to get the other one done.
