Just got mine today. Thanks. Need to install.
Digital volt meter. Fits in OEM switch location!
Originally posted by amcink View Posta quick DIY on how to install it will be helpful
meter wiring/BMW (non OEM radio), factory wiring
switched / red if switched from radio, gray with red stripe from OEM wiring?
measure yellow if constant from radio, grey with orange stripe from OEM wiring?
ground / black or make your own, brown
test fit before gluing!!!Last edited by uuc328; 01-10-2013, 07:54 AM.
Originally posted by uuc328 View PostI powered it from the radio wiring, these were close and labeled lol. Doesn't really matter where you get power from, as Balleristic31 posted the defroster switch is another close option. The leads are super short, I recommend extending them to ease the install.
Ok update that concerns me with the defroster wire use: just went to see what would happen if I switched the defroster on, and the voltmeter died and won't turn back on :( still have to diagnose but id steer clear of these wires for now
Edit: fixed the issue by moving the voltmeters ground to the brown smaller ground wire on the defroster. Back to perfect again. I guess the big black ground wasn't a good spot. Either way just avoid itLast edited by Balleristic31; 01-10-2013, 04:21 PM.
-NICK
