4x100/5x120 Multi Lug hub conversion
  • Eddiemeister
    • Sep 2018
    • 71
    Hello fellow enthusiasts. I have teamed up with Clipz motorsport to offer their new 5 Lug product at a 20% discount. This new kit is completely plug and play and allows you to use your stock calipers and rotors. What makes this kit better than those other methods of going 5x120 is that it saves you the headache of piecing everything together using different components from other cars such as other hubs calipers control arms lollipops etc and best of all this kit retains the stock geometry, 57.1mm hub size and factory offset specs!! As an added bonus you can also run 4x100 wheels since the hubs are drilled for both fitments. Stud kits may also be used. Addtionally, there is an option for those abs equipped cars which comes built into the hubs. Hubs are CNC machined. Profesional installation is higly recommended (check terms and conditions on their website)
    20 spots available. 20 SETS ( front and rear kits) must be sold in order to qualify for the 20% discount. Deadline December 1st
ID:	9882101 Click image for larger version
ID:	9882102 Click image for larger version
ID:	9882104 Click image for larger version
    Here is a breakdown of pricing
    1)
    2 Front hubs with bearings NO ABS
    2 rear hubs with bearings NO ABS
    NO ROTORS
    €511.60 plus shipping & taxes or $705 USD + shipping
    ( if you decide to not purchase their rotors, you will have to drill your existing rotors to 5x120 and 4x100)
    2)
    2 Front hubs with bearings + abs
    2 rear hubs with bearings + abs
    4 multi lug rotors 4x100 & 5x120
    €798 plus shipping & taxes or $891USD + shipping
    3)
    NO ROTORS
    €582 plus taxes & Shipping or $650US + shipping
    4)
    4 multi lug Rotors 4x100 & 5x120
    €726.80 plus shipping and taxes or $810.05US + shipping
    - 92’ BMW 325i Vert MT2 S770A Appearance Package
    - 96’ Toyota Tacoma single cab 4x4 2.7L [DD]
    - 01’ Honda Shadow VLX 600 Custom Bobber
    IG| Eddiiemeister
  • Mike36
    • 1079
    Is the hub size still 57.1?
    • HCMW Adam
      • Oct 2016
      • 209
      This is a really slick idea. Great job!
      • Eddiemeister
        • Sep 2018
        • 71
        yes 57.1mm hub size for now. They plan on rolling out a 72.5 hub size in the future along with 5x120 lug pattern hubs. This kit is ideal for those that want to run both lug patterns or would like switching wheels whenever they want by simply adding or removing a lug nut to each wheel. No more filling and drilling your wheels !
        IG| Eddiiemeister
        • Eddiemeister
          • Sep 2018
          • 71
          Bump cmon guys!
          IG| Eddiiemeister
