Koni SRT.T
  • 416stroker
    • May 2008
    • 2448
    Koni SRT.T
    From a 94 mustang. Installed those in the rear of my car and man it made a huge difference. There pretty much perfect nice and firm. If any one is looking not to spend a arm and a leg on rear shock I suggest them. The bodies are about 2.5 inches shorter than my old shocks.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    how much did you pay for them?
    • 416stroker
      • May 2008
      • 2448
      $120 for the pair from Jegs
      I think IM going to give the corrado fronts a try (if there drop in)as well if I cant afford the Ground Contol Koni's
      84 318I Delphin RIP
      89 325 Alpineweiss
      • chadthestampede
        • Jul 2008
        • 3601
        You have a link? The ones that I found are like $280. And pics?
        Originally posted by LJ851
        Feedback
        • 416stroker
          • May 2008
          • 2448
          http://www.jegs.com/i/Koni/610/8050-1050/10002/-1
          84 318I Delphin RIP
          89 325 Alpineweiss
          • Red88
            • Nov 2008
            • 1159
            What did you have before these?
            Have you made a purchase from www.blunttech.com recently?
            sigpic<< wrecked
            • 416stroker
              • May 2008
              • 2448
              The car had tokicos on it when I bought it and then switched to boge Turbos because the tokicos were to stiff. These are way shorter than both shocks.
              But I wanted somthing shorter than Billy sports so I went with these because I plan on going a lot lower. And the price was perfect. The ride is perfect its a little firmer than a friends car with Billy sports.
              84 318I Delphin RIP
              89 325 Alpineweiss
              • Red88
                • Nov 2008
                • 1159
                That's exactly what I wanted to hear. Thanks a lot!
                sigpic<< wrecked
                • 87e30
                  • Jul 2008
                  • 5676
                  They just bolt straight in?
                  I just hate everyone.
                  No need for discretion.
                  • M-technik-3
                    • 18946
                    GC used to use the DA and SA Koni for this mustang for the rear.
                    • 416stroker
                      • May 2008
                      • 2448
                      Yes
                      84 318I Delphin RIP
                      89 325 Alpineweiss
                      • Trucidatio
                        • Apr 2009
                        • 784
                        Would these work even if your car wasnt slammed, just lowered 1.5"
                        "I go slow, cause;Slow is smooth, and smooth is fast."
                        • 416stroker
                          • May 2008
                          • 2448
                          They do what springs are you running? I have German spec H&Rs ATM with no spring pads. I haven't installed the coil overs yet. I'm waiting on some front end stuff.
                          84 318I Delphin RIP
                          89 325 Alpineweiss
                          • Wh33lhop
                            • 11705
                            Do you have a basis for comparison between these and the regular off-the-shelf E30 rear Konis? I've got brand new G60 fronts and E30 rears with like 10k on them, if these will add back the travel (and then some) then I'm down. Just as long as they aren't TOO short as overextension is worse than bottoming out.
                            If you're running German H&Rs with no pads that puts you at what, maybe a 2" rear drop? No topping out of the Konis yet?
                            paint sucks
                            • 416stroker
                              • May 2008
                              • 2448
                              No I have ran the E30 rear koni's. I was thinking about it till a friend told me to get the stang billy HD's But after doing some searching around I found the konis and everything I read it sounded like a better shock. They shouldnt overextend under driving conditions. I havent had it happend yet.
                              I probably have close to a two inch rear drop. The rear arch is just flush with the rear tire. 16"w 205/45
                              84 318I Delphin RIP
                              89 325 Alpineweiss
