For you track guys that do this a lot i would definatly recomend this to you, takes longer to get the car in the air than it does to bleed your brakes with this, dump fluid in it, pump to 15psi, open bleeder, tighten x4, done.
easy as that, pedal is rock solid. makes bleeding a snap.
