Classified Forums - Read this first!
Here's a few simple guidelines for this forum. Failure to follow any of these rules will be grounds for your thread to be closed
Post your information
Post as much info as you can. Say where you are located, where the part is located, the best way to get in contact with you, if you are willing to ship, etc.
Post the items information
Post as much info as you can. A price must be posted, as well as pictures of the item(s). Post as many pictures as you can, even if it is a common item. A picture tells a thousand words, but it can also conceal another thousand. Links to hosted galleries of images are acceptable, links to eBay and/or Craigslist are not. Once the item sells, please do not edit your ad to remove the price. Many people search through old ads to get an idea what their item is worth.
If listing a car
-Post the year and model
-An accurate mileage. If the odometer is broken, post what it is currently at and how many miles you believe it has
-Any aftermarket modifications
-Any known issues or damaged areas
-Post a price
-As many pictures as possible of every area
If listing wheels and/or tires
-Post the brand and model
-Post as many specs as you can, including but not limited to tire size, tread remaining, wheel diameter, width, offset, bolt pattern and centerbore, if multi-piece the lip, barrel and center size. If they have been redrilled post the original bolt pattern and where it was done.
-Any imperfections, including but not limited to curb rash, bends, cracks, repaired areas, scratches. If tires, any gashes, bubbles, cupping and curb rash
-Post a price
-As many pictures as possible of every wheel
If listing Parts
-What brand and what models it can be used on
-An accurate description
-How long it/they have been used for
-Any imperfections
-Post a price
Miscellaneous items
-A detailed description of the item
-How long it/they were used for
-Any imperfections
-Post a price
WTB threads
-Be as detailed as possible
-List exactly what you want, what variations you will accept, colors or materials, etc.
-Post what you won't accept. This includes imperfections, colors, models, etc.
-Post what you are willing to pay. Only douchebags will bump up their price if your price is higher then theirs.
-Where you are located and if you would prefer local pickup only
In case the point was not made, everything being sold must include a price and as many pictures as possible.
-This is not eBay or Craigslist. Do not post links to either for your ad. The same goes for other forums. Either post your information here or have your thread closed.
-Feeler threads are not allowed. If you're not sure about selling it, don't post it.
-If listing your item for trade, post what you are looking for, what you feel your item is worth, if you would like cash back or if you have cash to put on top
-Thread crapping is not allowed. If you're not interested in purchasing the item for sale or have nothing positive to add, please stay out of the thread or else be prepared for a time out. If you complain about the time out, it will be extended.
-Only bump your thread once a day. You are allowed to respond to others more then once a day.
-If listing multiple items, post them in one thread. Exceptions are cars and wheels.
See more
See less
Coolerworx BMW short shifter
    I wanted to review this product because I have been so happy with its performance, quality and the customer service behind it.
    For literally years I have been chasing the "ultimate" short shifter. What I wanted was a shifter that had "zero" free play in gear, made short crisp shifts and inspired confidence banging through the gears not catchign any gates on the way or accidentally slipping into the wrong place. That it has taken me so long to find one that accomplishes all of this really has nothing to do with the quality or performance of previous products I've tried (they all were incrementally better, and the best of their design), the whole shifter mechanism needed a redesign. And that is where coolerworx nailed it.
    I had been browsing all over trying to figure out how to further improve the shifter when I started to come across people using similar shifters/designs as the coolerworx product. After reading several reviews and watching videos (and noticed Chris Harris using one in his E30 M3 rally car) I decided I needed to somehow get one of these in my life and try it out (obsessive compulsive much). Shortly after, I came across the coolerworx product with a reasonable price and made in America so I called to see if one was in stock in black (it was) and it was shipped to me the next morning. Great customer service from the start.
    A couple of days later it arrived and I felt like a kid on christmas morning. Packaged very nicely and beautifully finished in black.
    The problem with even the best short shifters out there isn't the quality of the product, their design or function. It's inherent in the function of the transmission. Even the best combination of shifter and selector rod will be handicapped by the transmission it's attached to. In my case, I eventually ended up with zero free play in any of the shifter linkages, but in each gear there's still free play within the transmission itself. When making very quick shifts it was possible to misshift (catch a gate going into a gear, or put it in the wrong gear). Mostly for me this was an issue going into 3rd gear from 2nd gear on a quick snap of an upshift. Frequently I would push it into 5th or catch the edge of the gate on either side and make a mess of the shift having to try to find 3rd while the engine just hit 7k rpm and revs are dropping rapidly (thank you super lightweight flywheel :) ). This is no longer an issue whatsoever.
    A few days after I received the shifter I was able to get some free time to install it. I purchased it with a universal base and in hindsight it probably would've been best to use the e36 base but it was hard to tell until I had it in my hands. Being the avid DIYer the small modification I had to make to the base was no big deal. And I am sure coolerworx would've shipped me a different one, but I didn't want to wait.
    Since only 4 of the mounting holes initially landed on sheet metal, I notched and bent the rear two sections of the base outwards so they would land on metal. This also allowed me to reuse the oem shift boot.
    Some detail shots of the awesome finish and quality.
    All the tolerances are very tight, rotating surfaces have ball bearings and most of the joints are adjustable and/or able to be serviced/disassembled. The hardware is all quality and the surface finish is very nice as you can see. Not really sure if it shows well in the pictures, but the main pivot (mounted with countersunk allen bolts and countersunk washers) is adjustable with 3 positions making the shift either a little shorter or a little longer. I have it mounted in the middle hole (which is how it shipped) and it feels very natural.
    The main advantage of this shifter is the ability to "set" each shift gate via set screws (shown below). Once the shifter is mounted, you select each gear and adjust the screws to dial out any free play (of which there isn't much to begin with). The other advantage to the set screws is that you can "lock out" reverse and 5th via the set screws if you choose to do so. To access a gear that's been locked out, you pull up on the ring under the knob which releases the pin that normally limits gear selection along with the set screws. I currently have mine setup to lock out both reverse and fifth gear.
    Mounting the shifter in the e30 does require the center console and ash tray to be clearanced/removed/modified and will no longer allow a shift boot (unless you make something custom). I started to make a panel to cover the exposed section around the shifter which should look great when done.
    I finally got a chance to rip on the car this weekend through a couple of early morning canyon runs and I must say the shifter is phenomenal. I have absolutely no uncertainty changing gears now wondering if I'm going to hit fifth, or catch a gate. It just snaps into gear; very satisfying. Effort is a bit higher than a normal short shifter, but it's not in a bad way. More of a confident click into gear. With the clutch/flywheel that I have combined with this shifter, changing gears is finally limited by my ability rather than mechanical components. I've never been so satisfied nailing a rev matched downshift or snapping an upshift under wot.
    Highly recommended!
    I will post a picture up when the install is complete.
    Shadetree30
    What does that cable do on the top end of the shift knob? Have always been curious to see one of these action... it looks like a really really well built piece!
    Can you shoot some video of it in action?
    Need OE BMW or Aftermarket Parts? Shoot me a PM! | Leave me feedback here
    (631) 393 0334 | info@omgmotorworks.com
      Was hard to understand the lockout mechanism but the video does a decent job summing it up.
      Swanny!
      SUCKERS.
        http://www.youtube.com/v/cGQrFlxPi3s
        your youtube bb code didn't come through there and that video doesn't load for some reason.
          So awesome. I want it. I miss third occasionally and it's always a humbling experience
            That cable is part of the lockout mechanism. I'll attempt to describe the function a little better (hopefully you also found a video that helps explain). If you take a look at the thrird to last picture I posted, top view of the mechanism, you'll see a pin with a spring around it. When you pull the ring under the shift knob, it retracts the pin so it's no longer sandwiched by the set screws. After that, the shifter is free to pivot fully left or right and able to access reverse and 5th. Normally those set screws and pin limit the left/right movement so that only 1,2,3,4 are available.
            Did that help? Maybe I can get a video later
            Shadetree30
              yea, it would break my heart when I would shift into 5th, or catch a gate trying to find 3rd
              Shadetree30
                maybe this illustration will also help
                Shadetree30
                  Very neat. The description above cleared it up for me! Looks like its a joy to row through the gears man :up:
                    Very cool shifter, I looked at their site to see what sort of a price range these are and I was very surprised. I was expecting a much higher price point.
                      It's fantastic
                      Yes, I think the pricing is very fair
                      Finished the install with some plates covering the ash tray and shifter surround
                      Shadetree30
                        Image isn't popping up (might be me...)
                          So you have to pull the ring up to shift into 5th?
                            I believe its only for reverse.
                            1990 325iX - sterlingsilber metallic
                            1991 325i - lazurblau metallic
                            Originally posted by delamaize
                            E30 = Lego for men.
                              You can set it up to lockout both 5th and reverse, or only reverse. I have mine set to lock out both.
                              Sent from my SM-G920T using Tapatalk
                              Shadetree30
