There's 2 kinds of E30 owners out there. If you remember The Odd Couple TV show, the 2 types are the Felixes and the Oscars. This product is designed for Oscars only. IF YOU ARE A FELIX, THEN THIS THREAD IS NOT FOR YOU.
This product is 2 wedges (made from PVC pipe) per rear subframe bushing that take up the air space in the 2 grooves found in OEM bushings:
You have to remove the car-to-subframe bracket on each side. The instructions call for driving the stabilizers in dry with a hammer. I cleaned the bushing holes with MAF cleaner, gooped up the stablilzers with polyurethane caulk and pushed them in with a floor jack, a hunk of wood, and a random socket. I Let the glue dry for 8 hours before lowering the car back onto the ground.
Results: I have no way of comparing the results to fresh subframe bushings. I test drove over some bumps, potholes, and pavement transitions. Before, and using technical teminology, the car would go "clank-rattle-rattle-shake-clank." On the same obstacles, it now goes "ga-bump." I can also feel a lot more road-surface vibration now.
I'm very pleased with the product. Probably nowhere near as good as fresh bushings, but vastly better than the old ones prior to installing these. I've asked the Ebay seller to cook up some for the front control arm bushings so I can test them.
