Massive - GB on brackets for 280x22mm kits
  • Massive Lee
    • Sep 2006
    • 6782
    This GB is for the caliper adapters used on the 280mm x 22mm kit with Corrado rotors. This is shop price. You can buy your own Brembo discs, get some used Dynapro/Dynalite off eBay and do your own kit.
    Bracket kit includes all required fasteners.
    $150usd + shipping + Paypal fees.
    GB Requires 10 participants minimum.
    Complete kits still available for $750usd w/ RB slotted rotors
    Thanks for looking.
    massivebrakes.com
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    What model calipers are these compatible with?
    • z31maniac
      • 17566
      Wilwood Dynapro.
      Lee, does this include the hydraulic fitting to adapt the stock/stainless steel brake line?
      www.gutenparts.com
      • Massive Lee
        • Sep 2006
        • 6782
        Dynalite and Dynapro. Wide mount. DYnalite s now discontinued, but many will still want them as there are more pads available for that caliper. The Dynapro caliper is newer, so manufacturers are now shifting their pad production to that caliper.
        Wilwood Dynapro.
        The hydraulic fittings (1/8npt to M10) are not included, and I won't sell them separately. They only come when purchasing a full kit.
        What is included are two CNC'd caliper brackets, caliper-to-bracket fasteners, and bracket-to-strut M12 capscrews.
        No modification of the strut is required. ABS still functional. You must cut a bit of the heatshield to fit the bigger caliper. I suggest removing the heatshield.
        massivebrakes.com
        • Uber E30
          • 1409
          Can we get the PN on the dynapro/dynalite you use? Im SUPER interested in this!
          -Alex
          • z31maniac
            • 17566
            I'm surprised at the lack of interest.
            Lee, I'm guessing you'd have to get 10 people signed up and paid before you'd ship? I'm seriously interested in these brackets, but not waiting weeks for other people to cough up the dough.
            www.gutenparts.com
            • LowR3V'in
              • 4209
              Sorry if this question throws this offtopic, but I'm curious if you can
              get new corrado rotors, get them machined, ebay used calipers, new lines.
              For less then $600.
              What I'm saying is, is it worth it getting all the stuff yourself then buying
              it new from massive. If it's like $100 more for the massive stuff then I think it's
              not worth getting used items and machine time.
              • z31maniac
                • 17566
                You can get Corrado rotors from $45 a set to nearly $200 a set (for Racing Brake brand).
                You don't need new brake lines, just a standard to metric adapter (approx $12 for both). And I can't imagine getting the rotor opened would be much.
                Just depends if you are willing to do some work for yourself to save some money.
                www.gutenparts.com
                • Massive Lee
                  • Sep 2006
                  • 6782
                  Cheap rotors can indeed be had for under $50usd/pair. Brembo makes sloted/drilled/plated discs for $260usd/pair. Your choice. Machining the rotors will cost you about $30/$40/set at your local shop (enlarge center bore from 65mm to 66mm). No special brakeline is required if using a 1/8npt-to-M10 adapters.
                  A lot of time and skills were spent designing and machining the caliper adapters. It is sturdy, shiny and cheap. Just like Z31maniac mentionned, I don't understand why 10 people haven't signed up in a flash. Anyway, if you are tentatively interested, do not hesitate to add your name. Copy and paste. Make yourself an advanced Christmas present...
                  If you get used calipers, they must be Dynalite/Dynapro Widemount with 1.38" pistons, for 0.81" discs. It looks as the 6 pots Dynapro (DP6) will work too... Pricier though. But looks so nice and ricey.
                  massivebrakes.com
                  • e30love
                    • May 2007
                    • 831
                    This kit rocks guys. Been using it for 7 months, and still in love with it.
                    24v swapped
                    • Uber E30
                      • 1409
                      1. Uber E30
                      FYI:
                      I priced out a full setup with brembo blanks, new dynapro 4 piston calipers, bp20 pads, massive adapter, and 1/8npt to m10 for about 650 shipped. Thats a substantial discount and you can purchase it in segments for those who dont have the money saved up. Buy these!!!
                      -Alex
                      • Brian D
                        • Mar 2006
                        • 832
                        Originally posted by Uber E30
                        FYI:
                        That's what I'm doing, slowly accumulating parts to do the swap. I'm changing hubs at the same time, and going with the "bling" calipers.
                        These brackets are beautifully made. I'm really looking forward to putting it all together.
                        1973 Bavaria
                        • morvaman
                          • 71
                          1. Uber E30
                          2. morvaman
                          • LowR3V'in
                            • 4209
                            Would this setup fit behind the 15x7 "euroweaves"?
                            • Massive Lee
                              • Sep 2006
                              • 6782
                              Please define "Euroweave".
                              Profile here for all to check.
                              massivebrakes.com
