10% sale extended thru the end of September!
					42 Draft Designs Spacers and Adapters
 Are you guys now offering 15mm adapters? when I bought them they were 18mm for the lowest that you could go....1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
 2012 Passat TDI - DD Duty
 2008 GMC Yukon XL Denali - Kiddie hauler/grocery getterComment
 wait, so are you saying that even though 15mm is available, it's.. not.. recommended?
 I ask because I am considering purchasing a thinner set but I mean I don't want to have my wheels fall off.Comment
 Sorry if that was confusing. 15mm is available in 4 to 4 and 5 to 5 lug setups - this is because there are no overlapping lug holes, so the adapters are of a standard design.
 18mm is the thinnest available 4 to 5 lug adapter setup, because the design of the overlapping lug style adapters is different - 18mm is the thinnest offered, and that's due to physical space limitations.Comment
 Hello!
 Can you send me the details for a set of 4x100 to 5x120 adapters to run the 7 series style 5 16x8" wheels on a 89 e30? (I know I know, just like all the cool kids) It looks like a lot of folks are running 18mm all around and I just want to make sure that is correct.
 I found a cheap set of wheels on craigslist and want to make sure we can make it work out. There are pages and pages of this topic and it is a pain to sort through.
 Also if you know anybody that needs some stock 7 series 235/60/R16 tires let me know ;-) They seem to be about 10% over-sized for the e30 and cutting the fender would likely make the girlfriend about 100% unhappy. Will try the 205/45 most folks say works, and I don't mind fender rolling either.
 Thanks!
 -Q Comment
 PM sent.Hello!
 Thanks!
 -QComment
 I need the same info on what you sent q5quint. Except mine are 17x8 style 5. Which adapter do I need?Comment
