Custom Built & Test Fitted 24v Swap Wire Harnesses
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    ** We are starting to produce these again. I have updated the thread with new pricing. If you have any questions we encourage you to contact the shop and speak to us directly. 865.246.6569 **
    Kadunza is now offering 24v OBD1 and OBD2 wire harnesses custom built to order for your specific chassis and test fitted into M42 wire covers.
    Basically our wire harnesses are not only "plug and play" they are also test fitted to ensure a quick easy installation in your engine bay. No fuss, everything is already test fitted to mount or route right where it should.
    (Please excuse my cell phone pics, I will update them as soon as I get a change to use a real camera to take pictures of the next harness.)
    This includes:
    - Wire harness is thoroughly cleaned and degreased before it is modified.
    - Trim and drill the M42 cover pieces to ensure all wires have a nice tight and clean fit.
    - C101 completely repinned with new OEM pins to match your year / make.
    - Connectors are appropriately rerouted to be E30 chassis friendly.
    - Connectors have printed labels for easy installation.
    - VSS / CEL / C104 installed for early 84-87 E30s
    - A/C Signal Wire appropriately routed w/ new pin
    - Oil Level Sensor connector is appropriately integrated.
    - Complete wire cover set ready to mount.
    - Fully Functioning ABS & Instrument Cluster Gauges
    What you need to provide:
    ** If you cannot or do not want to provide these there are additional charges for these connectors.
    - 84-85 C101 Square Connector ($40 extra if not provided)
    - 84-87 C104 Connector ($20 extra if not provided)
    - 86-91 C101 Connector ($20 extra if not provided)**If we have stock
    - E36 OBD1 or OBD2 Engine Wire Harness ($150 extra if we have it in stock)
    Prices:
    84-85 318i / 325e - $500
    86-87 325e / 325es - $500
    1987 325i/is - $500
    88-91 325i/is - $475
    88-91 E30 M3 - $475
    90-91 318i/is - $450 (or subtract $25 from any other harness if you do not want the oil level sender wiring added)
    Subtract $75 if you do not want the M42 wire cover set.[/I]
    Optional Additions:
    Spal Fan Relay Integration
    - $50 if you provide the relay kit
    - $90 if we provide the relay kit
    We wire the Spal fan relay into the engine wire harness along with an additional BMW relay that allows the Spal fan to be controlled by both the auxillary fan temperature sensor via the low speed fan relay in the fuse box and also provides the option to override the relay and turn the fan on by a switch located inside that car.
    Generic OBD2 Port Integration
    - $40 if you provide the port
    - $50 if we provide the port
  • sk8freakrt
    • Nov 2011
    • 129
    Stoked my harness could be the model for your photo op haha. Thanks so much! Definitely have my seal of approval, most helpful guy I've come across in the e30 scene!
    Sent from my Galaxy Nexus using Tapatalk
    • tytypetersen
      • Mar 2012
      • 347
      Wow! This looks great and awsome price. Will definitely be looking into this when I get my m52 put back together.
      • Schwartz-e30
        • Sep 2011
        • 160
        These look GREAT! Will be placing an order shortly.
        DD: 06 ZSP 330i
        Non DD: 91 332is slicktop
        • golde30
          • 11464
          this is an awesome product, with wire harnesses going for $100-200 in unknown condition and un-modified for e30 swaps, this is a bargain. paging Steven.
          IG: @Baye30
            • 37832
            Very VERY nice!
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • netcsk
              • Apr 2004
              • 1609
              Do want!
              • sk8freakrt
                • Nov 2011
                • 129
                Just got mine in today! Couldn't ask for better quality!
                • Steven
                  • Dec 2012
                  • 2305
                  What's the return time like on these?
                  Feedback!
                  Custom Cup Holder Consoles!
                  Calypso Story--S50/Shaved and Tucked Bay
                  • pilotskillse30
                    • Dec 2006
                    • 1957
                    Serious good work
                    • RobertK
                      • Jun 2005
                      • 5864
                      Ships within 5 business days of your payment.
                      • Steven
                        • Dec 2012
                        • 2305
                        Originally posted by RobertK
                        Is this an OBD 2 thing?
                        Feedback!
                        • RobertK
                          • Jun 2005
                          • 5864
                          The single pin with the violet wire is for the A/C signal on all E30s. The light bulb and 2 pin connector are for 84-87 325e and 318i cars that do not have a CEL or VSS inputs that run through the C101. The 3 pin C104 is for the econo gauge and tachometer signals for the cluster on 84-87 318i / 325e / 325es / 325i / 325is. On 88+ models these all run through the C101 except the A/C signal wire.
                          We can do either OBD1 or OBD2 built so that everything works instead of just making the engine run.
                          • DTMbimmer07
                            • 1485
                            PM'd!
                            • RobertK
                              • Jun 2005
                              • 5864
                              All PMs replied to.
