GB: schrick cams and valve train parts
  • alex
    • 2024
    Originally posted by DrMcDave
    2000 euro based on the listed prices he gave for the two individually. sick setup if you can afford it.
    It's rather amazing how you are too lazy to convert euro into USD, yet you have no problem motivating yourself to answer questions that you should not be answering. This question was for John. Thank you.
    • Snowmann
      • Jan 2004
      • 459
      lmao thats awesome, ITBs arent DSP legal are they????
      • maxx-automotive
        • Apr 2006
        • 87
        right now we use a conversion rate of $1.25=1 euro, although I see
        the $ just fell again, it has been as high as 1.30 in the last 2 years.
        so the alpha N shipped would cost 798 euro = $997.50.
        (it is shown here: http://john.gmstech.de/e30airbox/ankit1.jpg next
        to an airbox setup for an S14)
        I was mistaken on the Dbilas, its 1454 euro = $1817
        ITBs are expensive.
        John
        • DrMcDave
          • 1793
          ITBs are expensive.
          John
          still a good price on ITB's.
          • matt
            • 3732
            Not for what you get from them, except braggin rights I suppose.
            Matt
            • mspiegle
              • 1026
              Thanks for the explanation John. Does the Alpha/N unit fake AFM voltages to the ECU or does it control the injectors directly?
              Yes, Maxx alpha N works for the M20, M30, S14, S38 (3.5l), S38 (3.6l),
              M88 (3.5l) and also have it running on an M50 with Dbilas ITBs and
              carbon airbox, the same airbox/ITB setup will also work on a US S50/2
              motor.
              HOWEVER -- unless you remove the stock intake manifold and go with
              individual throttle bodies, the gains from alpha N on a stock motor
              are not so large.
              the gains are larger on ITB setups, because having an AFM in front of
              an ITB setup is similar to putting a single throttle body in front and
              causes a flow restriction and reduction in throttle response, so deletion
              of AFM and replacement with alpha N makes more sense.
              If you run different cams, then the flexibility of the alpha N is nice
              to have. Because you can just hookup your laptop and tune on the
              fly (while the engine is running) -- changes take place immediately.
              It is very simple procedure.
              I often tune alpha N setups on the street, but you should have a
              wide band lambda guage installed so that you can accurately measure
              AFR. see innovate motorsports or www.wbo2.com e.g.
              once you have that sort of setup installed, then you can think about
              playing with intake runner sizes (for the ITB) and plenum volume/shape
              to make a carbon plenum (known as an "airbox" in europe), this
              serves as a cold airfeed from the front bumper, the carbon is an
              excellent heat shield and keeps the air cooler, the increased plenum volume increases efficiency and the intake runners can be tuned for
              torque/power or a combination. The larger the cam, the more
              this sort of tuning pays off, and larger displacements accept larger
              cams more readily, as long as the top end can breath. Its all a system.
              John
              Michael Spiegle
              '01 Ford Escape / Daily Driver
              '99 M3 / Track Car
              '87 325is bronzit / wtf car
              '06 Daytona Triumph 675 / Daily Rider
              • alex
                • 2024
                They are.
                • maxx-automotive
                  • Apr 2006
                  • 87
                  Matt
                  Hello,
                  There is no question that ITBs provide real gains in power and
                  throttle response, otherwise they wouldnt be so common on sport
                  motors. Both the normal intake manifold and the single TB contribute
                  to power loss. If this were not important, manufacturers would not
                  look for new ways to eliminate throttles altogether --- hence
                  the reason for BMWs variable valve lift technology or electromechanical
                  valve actuation (cam less engine). Normally aspirated engines are
                  particularly tough, as advancements come in steps and the total
                  system is what counts. Nevertheless, with the right hardware on
                  4V / cylinder heads, power per liter in the range of 130 hp / l
                  are possible and often achieved. If you just bolt something on
                  but dont adress other components in system, it is to be expected that
                  gains may not be as high as possible. ITBs are probably too
                  expensive for most people to just bolt on and do nothing else
                  to the motor; for the the guy wanting building up an engine from
                  scratch it is definately something to consider (budget and class
                  rules permitting).
                  John
                  • maxx-automotive
                    • Apr 2006
                    • 87
                    Hi Michael, it does not "fake" AFM voltages in the sense that it
                    intercepts or post modifies the signal from another device,
                    what it does is synthesize electronically the AFM signal and
                    provide that to the stock motronic.
                    The signal is synthesized from values entered in
                    a 16x16 table (also called a map), x-axis corresponds to rpm
                    and y-axis to TPS (throttle position). The Z-axis is the load output
                    for each rpm and TPS site, which in effect sets the fueling.
                    From load the motronic computes fueling and it is compensated via
                    a "lambda trim" map on chip. But it is also possible to set the trim map flat
                    (no adjustment) and do it all within the alpha N unit.
                    The site positions are user adjustable,
                    and allow clustering of sites around specific problem/difficult to
                    tune areas a motor might have.
                    In addition to the base map, there are tables for ICV (idle control valve)
                    (in an ITB setup), additional temperature compensation, and its
                    own onboard O2 PID controller with user adjustable PID parameters
                    (for the case where you dont use motronic O2 control).
                    It also has on board logging and can display and log wideband O2 data.
                    3 shift lights with user programmable rpm points are also supported
                    (user just needs to add LEDs).
                    John
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      Maxx:
                      Do you have any, or possibly be able to get, an intake cam for a non-vanos m50 with somewhere around 254 duration and 10.4 lift?
                      My 2.9L Build!
                      • maxx-automotive
                        • Apr 2006
                        • 87
                        sure M50 motor (until 9/1992):
                        0261 E1 561 - 00 10.4 lift 256 duration 106 peak timing
                        0261 A1 441 - 00 9.5 lift 244 duration 106 peak timing
                        both cams are $460 each.
                        John
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          When does this GB end and when do I need to place my order? Etc, ETC, Etc..
                          My 2.9L Build!
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            nevermind, email sent
                            My 2.9L Build!
                            • maxx-automotive
                              • Apr 2006
                              • 87
                              if interested in parts, you have to tell me via email so I have your name on the list.
                              by end may. then we need all payments before we can
                              place the orders.
                              John
                              • DrMcDave
                                • 1793
                                is alpha N able to control spark? It doesn't sound like it but i figured i'd ask.
