We've had so much interest in our new E46 control arm conversion bushings for e30s that we had to set up a pre-order.
Most of you already know that the E46 control arms will significantly increase your front camber and also give you more clearance for more steering angle. Our new conversion bushings are machined from UHMW due to its high rigidity and low coefficient of friction allowing for minimal suspension bushing deflection (geometry change). We've designed them with an offset to re-center the wheel, and give your e30 the correct caster. They will include a metal sleeve/insert that will press very tightly over the hex on the E46 control arms. Once installed, as the control arm rotates, this metal insert will also. You do not need to grind down your control arms or make any other modifications to your chassis. Please note that you will need to use E36 outer tie rods and E90 inner tie rods. Let us know if you want us to source them for you.
The UHMW on this version is not as long as the production version will be.
