Shadowline Motorsport - LED Bulbs & Accessories
  • djmossm42
    • Jul 2012
    • 687
    R8 LED Headlight Bulbs - 4200LM/Bulb
    $64.99
    More Details!
    Improving upon the design of the R7, the R8 amps up the output to 4200LM!
    The R8 is one of the most compact bulbs on the market. It features a 1mm thick shaft that greatly reduces dark spots and increases effective light output. By positioning the LEDs as close to the original focal point as possible you can expect less glare and better performance than most other LED bulbs. Our bulbs come with the larger higher output Y19 Korean LED chips.
    Key Features
    - Korean Y19 chips are arranged in two 1x3 arrays 180° apart.
    - Compact size comparable to standard bulb
    - Highly effective lumen output @ 4200LM/Bulb. Luminous point is only 1.00 mm
    - IP68 water/dust proof
    - All metal housing
    - Available in 3000K,5000K,6000K
    - 24 Month Warranty
    What's in the package?
    - 1 Set = 2 bulbs with built-in drivers
    _________________________________________________
    R7 LED Headlight Bulbs, 3600LM/Bulb - 5700K
    $64.99
    More Details!
    The R7 introduces a brand new design that delivers high efficiency in a small package. Don't let the lower lumen rating put you off, these bulbs are bright and effective.
    Key Features
    - Genuine Phillips ZES chips are arranged in two 1x3 arrays 180° apart.
    - Fanless design
    - Highly effective lumen output @ 3600LM/Bulb. Luminous point is only 1.25mm
    - All metal base and collars
    - Available in 5700K (White)
    - 24 Month Warranty
    R6 LED Headlight Bulbs, 5800LM/Bulb/6000K Only
    $54.99
    More Details!
    The R6 builds on the solid foundation of the R4 and adds 2 more banks of LEDs for a total of 4! Since the light is more evenly spread across the reflector, you can expect a bright and full beam and a nice hot spot! The compact design makes converting from halogen to LED a simple task for most applications.
    Key Features
    - Fanless design
    - Compact size
    - High Lumen output @ 5800LM/Bulb
    - LED chips are arranged in a 1x4 array every 90° around the shaft.
    - Only Available in 6000K at this time
    - 24 Month Warranty
    - 1 Set = 2 bulbs with drivers (ballasts)
    - Grommets for advanced retrofits
    - Quick Install booklet
    R4 LED Headlight Bulbs, 4800LM/Bulb, 3000K/4300K/5000K/6000K/8000K
    Videos:
    CLEARANCE SEE WEBSITE FOR CURRENT PRICE
    More Details!
    The R4 LED bulbs are very bright and do not produce any EMI (radio interference), they do not have a visible flicker, and have a lifespan >30,000 hours. The design is based on the bulb type you are replacing so the LEDs are positioned in the same relative location to the reflector as the standard bulb for your headlights. The most interesting feature is the lack of a fan which is a common point of failure in other LED kits. Instead, the R4 uses a copper braided heatsink.
    Key Features
    - Fanless design
    - Compact size
    - High Lumen output @ 4800LM/Bulb
    - Base rotates 90° for best light emittance (Select bulb types only)
    - 5 color temperatures available (3000K, 4300K, 5000K, 6000K, 8000K)
    - Built in reflector to help spread and direct light towards the headlight reflector
    - 24 Month Warranty
    ACCESSORIES
    H4/H1 Inline Relay Adapter - Male H4 to H1 w/ Bi-Xenon Shield Connector - Pair
    $49.99
    More Details!
    Are you are planning to convert from sealed beams to HID or LED bulbs? Did you complete the conversion and realize your low beams no longer stay engaged when you activate the high beam? This is because the original sealed low beam is dual filament with Hi and low built in. You will find write-ups on using a jumper wire between the relays but you may not want to alter the fuse box or potentially jump the wrong terminals which could cause serious damage.
    This plug-n-play relay will keep the low beam on while the high beam is engaged. It also has a standard shield connector which is compatible with most bi-xenon projectors including our upcoming bi-xenon conversion kit.
    For cars with original H4 Connector
    Sold in pairs.
    Key Features
    - Plug & Play
    - Easy to return to stock
    - 24 Month Warranty
    - 1 Set = 2 plug in relays with H1 pigtails
    Illuminated Power Window Switch (PAIR) - 61311381205/61311377905 - E23, E24, E28, E30
    $11.99
    More Details!
    Aftermarket power window switch, replaces BMW part numbers 61-311-381-205 and 61-311-377-905
    Sold In Pairs.
    Key Features
    - Direct Replacement
    - Easy installation
    - 24 Month Warranty
    - 1 Set = 2 switches
    SHIPPING
    Orders to US Shipping addresses are shipped via USPS Priority at reduced rates.
    Orders to Canada will be shipped via USPS International Parcel at reduced rate
    TAX
    California residents pay 10%
    ORDER PROCESS
    1. Order is received
    2. We check local inventory for order, if available your order ships within 24 hours.
    2. If your order can not be fulfilled from our local inventory we will forward the order to manufacturer
    3. Production begins (Allow ~10 days)*
    4. Order is shipped to us, usually received within 3 days.
    5. Order is shipped to customer(s)
    * ALL orders requesting color temperatures other than 6000K require production if we don't have it in local inventory. There is about a 7-10 business day lead time from time you place your order to when you receive them. Any changes need to be made within 48 hours after the order was placed.
    WARRANTY
    All bulbs come with a 24 Month Warranty
    REVIEWS
    R6 LED Bulb review by Jeff (Redsubdivisions)
    IMPORTANT INFORMATION
    - For E30 Euro assemblies requiring H1 Bulbs, the small caps with socket may need to be modified. You can follow this write-up from one of our customers http://store.shadowlinemotorsport.co...ights_b_2.html.
    - If your car is equipped with sealed beam headlights, we recommend you convert to US Hella/Bosch projector assemblies, Euro Hella projector assemblies, or an aftermarket equivalent made by DEPO.
    LED BULBS ARE ONLY RECOMMENDED FOR HEADLIGHT SYSTEMS DESIGNED FOR HIGH INTENSITY LIGHT SOURCES, SUCH AS HID PROJECTORS WITH PROPER CUTOFF SHIELDS. CHECK YOUR LOCAL LAWS REGARDING LED BULBS FOR USE ON PUBLIC ROADS BEFORE PURCHASING.
    Follow Us On Instagram
    Wheelwell
    Shadowline Motorsport: LED & 3D Printed Accessories - 10% off for new customers!
    LED Bulb Thread
    R6 LED Review
  • 15Michaeljoseph
    • Aug 2013
    • 1693
    Any pics of output?
    Sent from my XT1064 using Tapatalk
    (OO=[][]=OO) For Life
    • djmossm42
      • Jul 2012
      • 687
      I will post today
      Sent from my MI 4LTE using Tapatalk
      Wheelwell
      LED Bulb Thread
      R6 LED Review
      • jayamasaki79
        • Oct 2014
        • 342
        Sorry, do these work right out of the box ? or do you need a pre existing HID kit installed ?
        I have the EURO smileys on my car, with NO HID kit in. Just stick bulbs, is this just a bulb upgrade ?
        thank you in advance.
        • glnr13
          • 1334
          these look really interesting. any night shots/vids of these in action?
          • djmossm42
            • Jul 2012
            • 687
            These are plug n play, they are designed with the same dimensions as the bulb it substitutes. No modifications needed to the housings. It comes with everything you need.
            Euro reps like depos, original bosch or hella Euro projectors use H1
            US projectors use 9006
            Wheelwell
            LED Bulb Thread
            R6 LED Review
            • jayamasaki79
              • Oct 2014
              • 342
              Nice, Thanks for the quick reply.
              Sent from my SM-G900T using Tapatalk
              • djmossm42
                • Jul 2012
                • 687
                I just installed them today, so I will get some night shots in a few hours
                Wheelwell
                LED Bulb Thread
                R6 LED Review
                • djmossm42
                  • Jul 2012
                  • 687
                  Night Shots!!
                  Stock E92 328i M Sport, Stock Hid bulbs (Left), My car on the right
                  Opposite wall, lights off
                  Opposite wall, lights on
                  Outside lights off
                  Outside lights on
                  Wheelwell
                  LED Bulb Thread
                  R6 LED Review
                  • glnr13
                    • 1334
                    Thanks for the night shots. What temp/color bulbs are in the video and photos?
                    • djmossm42
                      • Jul 2012
                      • 687
                      6000K
                      Wheelwell
                      LED Bulb Thread
                      R6 LED Review
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        Plug and play? Shit, you can't beat that. What bulb would be similar to common HIDs? I am looking to match my E46's stock HID's, preferably without the blue hue that I see in the videos.
                        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                        2012 Passat TDI - DD Duty
                        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                        • djmossm42
                          • Jul 2012
                          • 687
                          The closest match in color would be the 4300k bulbs, but will lean towards yellow.
                          Based on the bulb guide you need D2S which is an available option.
                          I used 2004 330Ci to look it up. The daytime running light is H7 which I can also get.
                          SYLVANIA is the leading automotive lighting supplier, providing high performance lighting products. Use our bulb replacement guide to find the right bulb that fits your vehicle.
                          Wheelwell
                          LED Bulb Thread
                          R6 LED Review
                          • glnr13
                            • 1334
                            cool, reserved a few sets.
                            • djmossm42
                              • Jul 2012
                              • 687
                              Thank you sir!
                              Wheelwell
                              LED Bulb Thread
                              R6 LED Review
