oilcooler
  • ethirty87
    • Aug 2013
    • 2
    oilcooler
    I have a M52 swap. I want to run an oilcooler setup and i have search but i found nothing that will work on my car sense i have a screw on plastic top instead of the metal bolt on top... Is there an oil cooler system for the screw on top plastic housings or am i forced to spend alot of money to switch it over? My second question is could i just run this http://www.ecstuning.com/BMW-E46-323....5L/ES1892558/ and tap into my plastic top? Whats the best way i should go about this with while keeping the price down.. Thanks :roll:
  • ethirty87
    • Aug 2013
    • 2
    also i do not have powersteering so could i bolt the S52 oil filter housing right up to the M52?
    http://www.ecstuning.com/BMW-E36-M3-...ystem/ES23926/
    • pr0craztinazn
      • Aug 2009
      • 204
      http://www.gutenparts.com/performanc...x-s50-s5x.html - This is a very well thought out solution, and gives you more options than a S52 oil filter housing will for adding an oil pressure, temperature gauge, and an accusump if you so desire.
      • bimmerteck
        • 762
        The best way I've found to add an oil cooler is the factory housing with built in thermostat.(not a cheap option but well engineered and less room for error) The Economotorsports from guten looks like a solid option as well but by the time you add in more fittings fittings and an external thermostat it's more expensive than it may initially look; but most solutions are when done properly.
