VSS issue - e36 obd2/91 318i
  • e30forlife
    • Mar 2012
    • 583
    PayPal bonus!!!
    I have the stupid VSS code that's making my car not rev past 5200ish
    The car is a 91 318i with a m52 obd2 setup.
    I keep reading about pin 9 on x20 is what I should wire pin 14 on chassis side. I cut a e36 chassis side plug off a donor car and wired it into my e30 chassis side. I only have 2 wires left on the chassis side that are not being used. A black/white one and a yellow/green I belive.
    On the chassis plug to the e36 x20 plug pin #9 is not being used nor 14!!
    Crisp $20 dollar bill for who helps me fix this issue :)
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    91 318 s52 Swap
    -m50 manifold
    -headers
    -zf320
    -3.25lsd
    -KaMotors Intake
  • JohnyEndo
    • Aug 2009
    • 64
    Go 14 to 14 on the c101/x20 the black/white on the e36 side should be vehicle speed if u gave a late model
    • e30forlife
      • Mar 2012
      • 583
      My pin 14 on e36 engine harness is deleted...
      91 318 s52 Swap
      -m50 manifold
      -headers
      -zf320
      -3.25lsd
      -KaMotors Intake
      • e30forlife
        • Mar 2012
        • 583
        What color would my c101 pin 14 be for a late model 91 318i?
        91 318 s52 Swap
        -m50 manifold
        -headers
        -zf320
        -3.25lsd
        -KaMotors Intake
        • JohnyEndo
          • Aug 2009
          • 64
          Blue/ yellow i believe.
          • JohnyEndo
            • Aug 2009
            • 64
            Just realized your obd2. instead of being pin 14 in The x20 it moved to X6031 pin 3. Still should be black/white
            • e30forlife
              • Mar 2012
              • 583
              This didn't work. I hooked up pin 14 white/black to x6031 pin 3. Still throws code.
              91 318 s52 Swap
              -m50 manifold
              -headers
              -zf320
              -3.25lsd
              -KaMotors Intake
              • e30forlife
                • Mar 2012
                • 583
                Blue/yellow is oil level sensor right? Confirm this?? Really frustrated with this. But then again its a swap...
                91 318 s52 Swap
                -m50 manifold
                -headers
                -zf320
                -3.25lsd
                -KaMotors Intake
                • e30forlife
                  • Mar 2012
                  • 583
                  Is there no one driving around with a late model 318i obd2 complete swap?? What did you do for the vehicle speed sensor?
                  91 318 s52 Swap
                  -m50 manifold
                  -headers
                  -zf320
                  -3.25lsd
                  -KaMotors Intake
                  • JohnyEndo
                    • Aug 2009
                    • 64
                    I dont know any obd2 guys at all. Sorry :/
