ZF310 and ZF320...differences?
  • nsxguy7
    • Sep 2013
    • 36
    So I just picked up a running 1992 e34 sedan. It has (of course) the M50 NV motor and ZF310 transmission. I have scoured the boards here to find the difference between the 310 and 320 ZF transmissions but no luck. Anyone have a clue? I am a newbie and just want to know that I'm not swapping in the obsolete or inferior version of the 320. Thanks!
  • butters
    • 1202
    Inconsequential from what I've read, I wouldn't worry about it being inferior. Non-vanos on the other hand....
    • DesertBMW
      • Aug 2011
      • 1030
      It is basically the same transmission.
      Differences are:
      310 means the torq rating in newton meters, BMW required regular ATF fluid with 310. The 310 has black plug covers for shift springs that tend to be better quality.
      320 bmw now requires you to use their own MTF-LT1, because of this they are now rating it slightly higher torq, thus the designation 320. The 320 has green shift springs covers and sleeves inside tend to have seizing issues.
      • butters
        • 1202
        Am I correct in understanding that ATF can go in the 320? I got mine from a specialist rebuilder, and they said it's a matter of preference and experience.
        I researched on BFc and also heard of many people running an ATF/MTF(gear oil) blended cocktail with good results.
        I really was unsure.. ATF is so drastically different from the 75w-80 MTF. Thinner which is probably good for cold weather, but just adequate in terms of longevity and protection where the gear oil does a better job?
        • agent
          Vice Grand Pubaa
          • 7960
          I am running Redline ATF in Lola's ZF320.
          Originally posted by kronus
          • nsxguy7
            • Sep 2013
            • 36
            Thanks for the info!
            • nsxguy7
              • Sep 2013
              • 36
              last of all...can anyone recommend a good source to rebuild the ZF310?
              • Wanganstyle
                • 2828
                Differences are:
                incorrect info;
                the 320 can use ATF happily - e36m comes with a 310 (1995) and 320 update (1996-99). Ask both zf5's in my street or race car.
                shifting detent spring things are a wear item in all the Zf 5 speeds, 310 or 320.
                ATF and MTL seem happily interchanged between the two; the getrag 6 speed units seem to Hate Manual trans fluid 75-90 (e39 m5 / e46 m3); i filled my 6mt with mtl and ended up draining it to refill with ATF - the thick MTL hated shifting untill gearbox was warm. ATF filled the 6mt getrag and it was happy - climate was Northern california; not ever cold.
