318is m50 SWAP HELP!
  • Cforsett
    • Oct 2015
    • 2
    I have a 1991 318is e30 that I would like to swap an m50 into. It comes with a ZF transmission out of a m3. I kinda don't want to use any of the g240 stuff because its weak. It also comes with a giubo adapter.
    -First question is with a m50 and ZF and the giubo adpator, can I run my stock e30 driveshaft? Do I need different tranny mounts? Do I need to mess with my shifter linkage to make it straight? *Also, I need to get the bellhousing for the ZF, and instead might buy this complete getrag 260 tranny and block I found for cheap. If I do that, will all the m20 stuff bolt up to the m50?
    -My second question is what flywheel, clutch, slave cly, and starter should I get? Will m20 or m42 stuff work? Or should I go all e36 stuff? Money IS AN issue.
    -Third question is can I use my stock m42 clutch fan, or should I go electric?
    -Last question is will my stock m42 o2 sensor work with the m50, or does it need to be messed with?
    Thanks! Any other advice on doing this swap is DEEPLY appreciated.
  • R1dd1ck913
    • Jul 2014
    • 382
    No you can not use your stock drive shaft. When you go form the 4 cyc to the 6 cyc the motor and transmission move backwards. This also means you will need a shorter shifter linkage.
    I used my g240 with its starter, clutch, slave and so on. Since money was an issue for me.
    You will problay have to go electric. A clutch fan does not really fit all that well.
    The m42 and m50 o2 are the same. I think the only thing was the wire was longer.
    Current
    99 328i (Sold)
    91 318is M50B25TU
    89 325ix (Parted out)
    87 325is (Parted out)
    95 525i (Parted Motor for 91 318is)
    • Cforsett
      • Oct 2015
      • 2
      So the 240 and its starter, clutch, slave, etc will work with a m50? And is the stock clutch and tranny holding so far? And the starter is powerful enough? Did you have to mess with the drive shaft, shifter linkages, and/or tranny mounts?
