Since I've completed the swap I've had some parasitic load from my battery when the car is off. I've recently discovered there is no load if the MAF is unplugged. When the MAF is plugged in it draws a full amp from the battery when everything is off. I've replaced the DME and the MAF itself with no luck. The engine is an M50B25TU. Any help would be appreciated.
