M50 with g260 strange noises
  • florida_dirt
    • Feb 2013
    • 497
    I've put about 10k miles on my swap so far and started noticing a weird 'clinking' noise coming from the clutch/transmission, only happens when I shift the car hard at higher rpm's. Did some research online and couple people with similar noises say it could be 'flywheel chatter'. It doesn't effect the drivability at all, as long as I let the clutch out slow you'll never hear the noise.
    Then last night I noticed a new noise, it sounds like a scraping/very light grinding noise at around 3k rpm.. The noise goes away with the clutch engaged.
    Just looking for any input from anyone who has had similar issues or heard of similar problems.
    Car has g260 with ETA flywheel and clutch. I could get a video of the sound later today if that would help.
  • bmwfan52
    • May 2016
    • 118
    same thing with my s52 getrag 260 swap
    i wanna just put a zf in and ease my nerves but ive already put so much work into geting her in there
    • bmwfan52
      • May 2016
      • 118
      update-
      took apart my getrag and flywheel bolts were grinding the clutch springs
