E34 V8 brake booster for M50/52 swap
  • GK-E30M3
    • Apr 2008
    • 816
    dose anyone run a e34 brake booster i searched with no results please help thanks
  • omar85
    • 331
    i have seen it done. if you need one PM ill sell you my complete setup on the cheap.
    • hi its me alec
      • Apr 2008
      • 478
      I'm running an e32 740i brake booster with e34 525i master cylinder. It's cool because it has a remote brake reservoir setup, perfect for an e30 M50 swap.
      WTB: early e30 sedan front doors
      • Jean
        • 18228
        Interesting. How are the brakes performing with this configuration?
        • flyboyx
          • 8371
          i think that ought to work out well. another option if you want more braking power would be to take the hydroboost system off of an e23. i have the better part of a write up on this in my thread in this 24v swap section.
          Gigitty Gigitty!!!!
          • rThor432
            • Feb 2007
            • 3907
            A friend of mine is running the E34 530i/540i brake setup with his V8 conversion. He has the booster remote located, like the E34 V8 cars, behind the headlight. It works great. He just had to fab up a couple of brackets. I think he relocated the ABS unit a bit lower than it's standard location, but I'm not positive about that.
            This setup would work the same way with the M/S5X motor.
            • hi its me alec
              • Apr 2008
              • 478
              They feel great... haven't had a chance to drive it yet. The pedal feel is so much more intense with this MC/booster combo, especially compared to my old broken parts.
              • Jean
                • 18228
                Alright, it's much easier for me to get an e34 v8 booster than iX or 944 booster so I'll get one. No modifications needed at all?
                • surebimmer
                  • Jan 2004
                  • 978
                  Alec
                  Did you mount it with the bracket on the back of the booster? That master is a 23mm unit correct?
                  • e30polak
                    • 6136
                    Uh oh...time to upgrade from the 320 booster when I go for bigger brakes...
                    INSTAGRAM: @UNDR8D_EMPIRE
                    • hi its me alec
                      • Apr 2008
                      • 478
                      Originally posted by surebimmer
                      Alec
                      I don't know how big it is, but no, I didn't use the bracket it came with. I just redrilled two booster holes and made the fork on the end longer, that way it mounted just like a stock one. I took the stock booster to my welder and he matched the V8 booster right up to it. Just extend the fork so the lengths are the same. Make sure the pin fits back in at the end.. it would suck if it didn't line up perfectly.
                      • hi its me alec
                        • Apr 2008
                        • 478
                        It was very easy to do. Just pick up the V8 booster with an e34 525 master cylinder. That way the hardlines are the same size. The V8 master cylinder hardline holes are bigger.
                        • GK-E30M3
                          • Apr 2008
                          • 816
                          hey Alec can you post some more pics of the booster in the bay i just bought same booster
                          • tweetyoost
                            • Jan 2010
                            • 10
                            Does the shaft of the brake booster lines up correctly in lenght and position to the pedal mechanism?
                            I'm planning to use a E34 540i booster+MC+remote reservoir for my E30 M50 swap.
                            • jahnaboi
                              • Oct 2006
                              • 1742
                              I did a 750il brake booster on my car. Double stacked but 25mm mc. I use the complete unit and no modifications were done other than the reservoir.
                              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
