for 88 s50 turbo m3?
Which and where to buy 255 walboro
got mine on ebay. in-tank pump. replaces with stock easily.No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5Rs -
88 e30/s50 gt35r turbo m3
96 gt4094r turbo m3
452 rwhp, 455 rwtq at 14 psi 91 octane
681 rwhp, 684 rwtq at 25 psi E65Comment
maybe talk a little bit about your setup...what in-line? and btw all them walbro's have the same flow.. there's like two different ones, a higher flow and higher pressure and a base.. housing does change. any one of em should work.No more e30s for me.
91 BMW 325i [sold]
http://youtube.com/watch?v=pTj7Hn9v5RsComment
Your car SHOULD only have an intake pump. The cutoff between the two pump setup to the one pump setup was sometime in 87. If you don't know for sure, look under the car in front of the drivers side rear wheel to see if you have a pump under there.Comment
My set-up is in my sig..All 255 I see are for in-tank application...The one I want to replace is the one next to the rear left wheel atop of the fuel filter..I'm using the stock fuel pump and it runs lean on high boost.88 e30/s50 gt35r turbo m3
96 gt4094r turbo m3
I thought the one by the fuel filter is just the sender? no? You have a 88 there should only be one pump by the gas filler side.Comment
96 gt4094r turbo m3
you/someone then added an external pump...tis okay, walbro..and ebay... have external 255 lph pumps. just grab any, they are all the same like i told you, just some have different housings ie offset inlet/outlets...bmw nissan toyota e30 240sx supra any. Stock or adj FPR?No more e30s for me.
91 BMW 325i [sold]
