oil out of flywheel bolts...
  • jakeb
    • 1909
    I just got an s52 to replace my m50 and I was mounting it up to an engine stand and took off the flex plate(from auto) and oil poured out of the lowest bolt hole. After I cleaned up about a gallon of oil off my new garage floor I was wondering if this is a problem....
    Also it was hanging from a engine puller, so the back of the engine was the lowest...
    So is this a problem? Or is there a way that oil can get to that area?
    tia,
    jake
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • BigD
    • Jul 2006
    • 1085
    It's not a problem, the flywheel bolt holes go right through.
    • lifeiskaos
      • 1709
      make sure to use loctite when you put the bolts back on
      • sharksforthecup
        • Aug 2007
        • 246
        tisk tisk, should have drained it first. J/k no matter how careful I am I always end up with engine fluids all over the floor.
