So the other day I got my 93 m50 running in my e30. Took a little while to get running and idling on its own. Now that is it idling somewhat good, and it seems to rev up quick and sounds okay when it is. When the car is running and holding at a certin RPM not really sure what RPM it is but if i were to guess i would say 3.5k, it is pretty rough sounds like it is missing and poping. Right now I only have ss rep headers on so no o2 sensor. I'm going to buy new spark plugs and a o2 sensor now, hoping that will take care of the problem. What else could this be?
running rough
Yeah I forgot to thank you, I appreciate the help that you gave me, I was able to figure most of the wiring out with help from my father. I just have essentials to get the motor running, I still have to hook up some sensors and what not. Ill probably PM you to see if our cars match up if thats cool with you, I think that will help me out a lot. Thanks again man!
No slave cylinder, I let someone use mine when my car was never close to running and they needed one, the guy never gave it back nor did he repay me for it....
I should be getting one in from the mail sometime this week though and I can tell you.
It shouldn't be running that rough minus the O2.
I would look for a vacuum leak first.
What sensors do you have to hook up?????Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
your right, I dont really expect a good running engine though without all the stuff hooked up, i'm just waiting on some stuff, so i just wanted to check what you guys thought, Ill try to clean it up then ill fill you guys in.
^^^what he said
My MAF was bad when I first got my swap going and it would stall out when i touched the gas very very slightly, i would have to gun it up to 2k ish and ease out of the clutch to go, or pop the clutch. It ran rough and I got all sorts of popping below 4-5k ish. After that Vanos would kick in like Vtec. After I replaced it, it ran fine after that. I kind of miss that sudden surge of power though :D
So def look for that when you can drive it. Or test the MAF with a voltmeter.sigpicComment
