M52 Oil pan gasket.
  • Swoozley Macklin
    • Feb 2017
    • 122
    M52 Oil pan gasket.
    Hey all, been trying to dig around. Is there any other way to go replacing the oil pan gasket without dropping the subframe? Car is M52/ZF based and dropping subframe isn’t doesn’t sound like fun right now. Are we able to remove the mounts and snake the pan out? I used to do that on my m20 car a lot? Tried digging around but kept finding m20 based threads. Just want to start to prep for this.
  • jbontke
    • Mar 2019
    • 449
    I don't think you will be able to clear the pick up tube. In the m20, some people removed the pick up tube and that gave them clearance. I am not certain that the m5x will be the same. I dropped my subframe, but i did not remove it from the car. I disconnected the steering rack to steering shaft. Then I removed the bolts and installed longer bolts that would allow the subframe to be lower but not be a mofo line back up with a jack. I found this easier than trying to install the pick up tube with an oilpan in the way.
    • Swoozley Macklin
      • Feb 2017
      • 122
      ended up doing this method. Wasn't as bad as expected. Thank you.
