Ok spent the last week researching a swap as my m20's timing belt just took a dump on me. I never liked the m20 much (probably why I never did the belt) so I am going for a swap. Goals are 200-220 rwhp out of the new setup. Below are my notes on what I have learned and have questions about. Any help is greatly appreciated...
Engine:
97/98 Z3 M52b28 w/ aluminum block
OBDII
EWS
S52 Cams
OBDI Manifold (M50)
All Accessories from M52b28
Need:
2 Keys (Preferably) }
ECU }
Antenna }
Signal Booster }All From Donor Car
ODBII Engine Harness
E21 320i Brake Booster (modded length)
E32 735i Master Cylinder
E28 535i Motor Mounts
E34 Oil Pan, Pickup, Gasket, Dipstick, Tube
E36 Mount Arms (same as Z3?)
E34 Throttle Cable
E36 M3 Exhaust Manifold (necessary?)
E30 Radiator, Overflow Tank (318is Rad/Tank?)
Electric Fan (probably use Volvo)
Tune for Cams & Delete Rear o2 Sensors
Rewiring at C101 (or buy adapter)
Transmission:
97 Z3 5spd (no overdrive)
Need:
M20 Trans Mounts & Trans X Bracket
E28 533i 3:25LSD (output shafts?)
E36 Driveshaft (328 & z3 same?)
Are my notes correct? Is that what I am looking at for the swap... plus small parts of course like hoses and fittings? Again thanks in advance. My brain hurts from all the swap threads and of course THE DOHC thread.
Engine:
OBDII
EWS
S52 Cams
OBDI Manifold (M50)
Need:
ECU }
Antenna }
E34 Throttle Cable
Transmission:
Need:
